06-23-2006 09:15 AM - edited 03-03-2019 01:06 PM
Does anyone know were to find a data sheet on the NMD-36ESW? Specifically I'm wondering what the bandwidth is on the switching fabric. Also the only info I see on STP is it supports 802.1d - what about 802.1w, RSTP?
Thanks.
06-23-2006 09:30 AM
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a00801aca3e.html
this will help you
rate this post if it helps
regards
Devang
06-23-2006 12:32 PM
Yes, I did see this but it doesn't give a bandwidth spec for the fabric. It comes close saying 200 Mbps per port (full duplex) which would be 7.2 Gbps minimum.
The pdf is (C) 2005 so I was hoping there was something newer which would indicate it can do 802.1w RSTP.
