12-15-2006 11:02 AM - edited 03-03-2019 03:03 PM
I'm not able to see the track (track_object) rtr command in IOS 12.3(4r)T3, but this command is supported in IOS Version 12.2(4r)B2 which is the downgrade IOS version.Can u pls help me on this issue.PLs find the show version and track commands supported on my router.
IOS (tm) 7200 Software (C7200-IS-M), Version 12.3(6f), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 16-Aug-05 21:42 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61C5C000
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(9), RELEASE SOFTWARE (fc2)
7206-Pri-Core-Rtr@Campus uptime is 26 weeks, 6 days, 12 hours, 43 minutes
System restarted at 12:34:57 IST Sat Jun 10 2006
System image file is "disk2:c7200-is-mz.123-6f.bin"
cisco 7206VXR (NPE-G1) processor (revision B) with 491520K/32768K bytes of memory.
Processor board ID 34599756
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Channelized E1, Version 1.0.
PCI bus mb1 has 400 bandwidth points
PCI bus mb2 has 400 bandwidth points
4 FastEthernet/IEEE 802.3 interface(s)
3 Gigabit Ethernet/IEEE 802.3 interface(s)
19 Serial network interface(s)
8 Channelized E1/PRI port(s)
509K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Router(config)#track 1 ?
interface Select an interface to track
ip IP protocol
Solved! Go to Solution.
12-18-2006 02:58 AM
12-15-2006 01:09 PM
Is there anyone who can help me ?
12-15-2006 08:42 PM
You have 12.3(6f) and you need at least 12.3(4)T10 for IP SLA.
Remember, T train and regular train aren't the same in term of features.
Download 12.3(4)T10 to fix your problem.
12-18-2006 02:53 AM
Do i need to upgrade the IOS to 12.3(4)T10 ?
12-18-2006 02:58 AM
Yes, as suggested by Edison in his last post.
-amit singh
