Input errors on Gig 0/0 (Multi-Vlan)
qasimkhans
     i am getting input errors on Router 3845 Gig 0/0 which is holding 4 Vlans, error are increasing after every 1 minutes. Router gig 0/0 was connected to Switch 3560G Gig 0/24. i changed the port to gig 0/23, changed the LAN cable (cable directly connected to router and switch not patch panel). changed the Duplex to Full on both end. changed the speed to 1000 on both end. but same issue. Duplex and speed was auto/auto on both end but i was still gettig input errors on router gig 0/0. then i changed duplex and speed as mentioned above. there is no errors on switch gig 0/23 and 0/24. the error are olny on router gig 0/0. please help me in this regards. my previous router had same issue therefore i change it with new router.
2 Accepted Solutions
Leo Laohoo
Post the following output:
1.  Router:  sh interface Gi0/0;
2.  3560G:  sh interface ; and
3.  3560G:  sh controller e
reliability 255/255, txload 3/255, rxload 3/255
When you enter the command "sh interface G0/0" on your router, have you ever seen the other values, above highlighted in RED, other than "255"?
17 Replies 17
Leo Laohoo
here is Router
ITC-R3845#sh inter gig 0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is BCM1125 Internal MAC, address is 0021.5537.7090 (bia 0021.5537.7090)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2d02h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 309
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 13223000 bits/sec, 2482 packets/sec
  5 minute output rate 12434000 bits/sec, 2504 packets/sec
     697378916 packets input, 2574884048 bytes, 0 no buffer
     Received 2908397 broadcasts (0 IP multicasts)
     4198 input errors, 0 CRC, 0 frame, 4107 overrun, 0 ignored
     0 watchdog, 806066 multicast, 0 pause input
     695752579 packets output, 3222896986 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     11 unknown protocol drops
     1 lost carrier, 0 no carrier, 0 pause output
here is Switch
ITC-Core-SW3560G-PoE#sh inter gig 0/23
GigabitEthernet0/23 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001e.7964.4997 (bia 001e.7964.4997)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 2/255, rxload 2/255
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:16, output 00:00:00, output hang never
  5 minute input rate 8917000 bits/sec, 1124 packets/sec
  5 minute output rate 8931000 bits/sec, 1419 packets/sec
     679051148 packets input, 471366142835 bytes, 0 no buffer
     Received 29559141 broadcasts (0 multicasts)
     271 runts, 0 giants, 0 throttles
     271 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 29256963 multicast, 7275 pause input
     919815108 packets output, 508855736468 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
ITC-Core-SW3560G-PoE#sh controllers ethernet-controller gigabitEthernet 0/23
     Transmit GigabitEthernet0/23             Receive
   2222457323 Bytes                       3387753980 Bytes
    914270731 Unicast frames               649657763 Unicast frames
      1248503 Multicast frames              29276769 Multicast frames
      4527692 Broadcast frames                302306 Broadcast frames
            0 Too old frames              3542007398 Unicast bytes
            0 Deferred frames             3350433303 Multicast bytes
            0 MTU exceeded frames           19444768 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames           238015639 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames              516129 Minimum size frames
            0 8 collision frames            97181678 65 to 127 byte frames
            0 9 collision frames           283317718 128 to 255 byte frames
            0 10 collision frames           23012528 256 to 511 byte frames
            0 11 collision frames           53790486 512 to 1023 byte frames
            0 12 collision frames          221425574 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames               7275 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
    237309472 64 byte frames               238015639 Valid frames, too small
     79130137 127 byte frames
    277555027 255 byte frames                      0 Too old frames
     22850034 511 byte frames                      0 Valid oversize frames
     55582617 1023 byte frames                     0 System FCS error frames
    247619639 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
i am sorry i mistakenly clicked on correct answer button.
did you have speed and duplex set?  Set it back to auto.
7275 Pause frames
Router is sending Pause frames to the switch telling the switch to STOP or slow down.
it was on auto/auto but i was still getting errors. if duplex is auto there is messages on router. duplex mismatch that is why i put duplrex full.
On the 3560G, try this:
1.  Command:  test cable tdr interface G0/23;
2.  Wait for 61 seconds;
3.  Command:  sh cable tdr interface G0/23; and
4.  Post the output to #3.
WARNING:  If your 3560G is running an old IOS, 12.2(44)SE and earliear, this command is disruptive.
Here is output
ITC-Core-SW3560G-PoE#sh cable tdr interface gig 0/23
TDR test last run on: November 21 20:46:15
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/23    1000M Pair A     0    +/- 4  meters Pair A      Normal
                Pair B     0    +/- 4  meters Pair B      Normal
                Pair C     0    +/- 4  meters Pair C      Normal
                Pair D     1    +/- 4  meters Pair D      Normal
i checked it but i did not find other than 255.
Keep an eye on it.  If it ever go below 255, change the cable immediately.
ok i will. but what you think about this issue. all the setting you saw. what is you the expert opinion on this issue.
My opinion is you could have a potential cable issue.  Can't be certain.  TDR is showing fine ... but then again TDR has to be precise and can sometimes require "perfect timing" to see the cable pairs drop.
ok i will change cable again. but i noticed that when traffic goes above 20mb on interface gig 0/0 then i receive input errors on interface gig 0/0. if traffic continue above 20mb then i contiue receive errors.otherwise there is no single error if traffic below 20 mb.
Make sense.  The router can't process the amount of traffic coming from the switch so the router sends the unprocessed data into a buffer until the buffer gets full.  When this happens the router stop dropping packets.
You may want to consider slowing down the amount of data going from your switch to the router by putting a QoS on the switch side.
but how is this possible a router cannot handle more than 20mb but switch can handle it.
