03-31-2006 06:15 AM - edited 03-03-2019 12:15 PM
Hi all:
I want to install a PA-T3+ card in a running 7204VXR, Is this card support hot swap so i dont need shutdown the router?
thanks in advance.
Solved! Go to Solution.
03-31-2006 08:46 AM
Per the attached link you can install without powering down.
Hope this helps.
Steve
03-31-2006 08:43 AM
Hi, this card should be OIR, online insertion and removal. Here is a link that should help.
03-31-2006 08:46 AM
Hope this helps.
Steve
