Community Member
INSTALLATION OF CALLMANGER 5.1 IS ABORTED IN MCS7825-H2
WHEN I TRIED TO INSTALL THE CALLMANGER 5.1(1B) IN MCS 7825-H2 SERVER THE FOLLOWING ERROR OCCURED AND THE INSTALL ATION IS ABORTED.THE ERROR MESSAGE WAS...
CRITICAL ERROR
[create.sh]: hrconf create argument: 1 LOGICALDRIVE Init
A selected physical device is not available for use.
Could not open log file :UcliEvt.log
controllers found : 1
Command aborted.
[create.sh]:ERROR: Cannot create SATA RAID
Controller Information
Controller Status : OK
Channel Description : SATA
Defunct disk drive count : 0
Logical drivers/Failed/De.... : 0/0/0
Command completed successful
.AFTER THE ABOVE ERROR MESSAGE THE INSTALLATION WAS ABORTED.PLEASE FIND THE ERROR MESSAGE AND GIVE ME THE SOLUTION FOR THIS PROBLEM.
1 REPLY
Silver
Re: INSTALLATION OF CALLMANGER 5.1 IS ABORTED IN MCS7825-H2
It is something wrong with the way the BIOS reports it. You have to let it rebuild the array and then redo the install.
320
