01-27-2009 08:28 AM - edited 03-04-2019 12:59 AM
I'd like to know the proper procedure for installation, please. Does it require the router to be powered off? Any help would be appreciated.
Best regards.
lf
01-27-2009 08:39 AM
this might assist you. But yes, you will have to have some down time.
regards,
01-27-2009 08:43 AM
here is a short step:
1. issue the "sh diag" to verify the slot
2. configure card type "card type t1 slot# where slot# is the one return from sh diag.
regards,
01-27-2009 12:25 PM
Thank you your help...I can't use "card" command though, not sure if it's because of IOS ver?:
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:09 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 19 weeks, 1 day, 2 hours, 59 minutes
System image file is "flash:c2800nm-ipbase-mz.124-3i.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FTX1234A0QF
2 FastEthernet interfaces
1 Serial interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Is it necessary to use this command?
thanks
01-27-2009 12:34 PM
Only for T1/E1 cards.
01-27-2009 12:44 PM
I am not sure but it should work with ver 12.4
Are you issuing the command from the config mode? what do you get from sh diag?
01-27-2009 12:57 PM
I have not installed 2nd WIC card yet; I have WIC-1DSU-T1-V2 card already installed in WIC slot 0, for the existing T1 line.Still I can't use "card" command, so I'm afraid that I will not be able to make proper configuration for additional T1 line..
sh diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC12323XKT
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 0
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080809
Chassis Serial Number : FTX1234A0QF
Chassis MAC Address : 0022.904d.8088
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
--More-- EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 32 33 32 33 58 4B 54 40
0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 68 A9 C2 8B 46 54 58 31 32 33 34
0x40: 41 30 51 46 C3 06 00 22 90 4D 80 88 43 00 18 C6
0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC122941SD
Part Number : 73-8346-05
Board Revision : A0
RMA History : 00
Deviation Number : 0-0
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
0x00: 04 FF 40 00 52 41 01 02 C1 8B 46 4F 43 31 32 32
0x10: 39 34 31 53 44 82 49 20 9A 05 42 41 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 CB 94 57 49 43
0x30: 2D 31 44 53 55 2D 54 31 2D 56 32 20 20 20 20 20
0x40: 20 C0 46 03 20 00 56 B1 03 C6 8A 49 50 55 49 41
0x50: 50 52 52 41 41 FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
01-27-2009 07:28 PM
That is a T1 only card and you don't need to enter card type command
01-28-2009 06:22 AM
Thank you to all who responded to my question.
lf
