Community Member
Installing VWIC2-1MFT-G703 in 2911 router
I have to terminate an E1 using VWIC2-1MFT-G703 Interface card on 2911/k9 router but as per my knowledge installing HWIC card in EHWIC slot requires an intermediate jacket but I am not sure. I shall be grateful if someone can guide me a) is it is possible b) how?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: Installing VWIC2-1MFT-G703 in 2911 router
Nothing is needed to install this card.
Note, unless you must using unframed mode, the expensive -G703 version is not necessary.
Hello!
A. Yes. EHWIC's  are of the exact same form factor as an HWIC. Hence any supported HWIC,  WIC, VIC or VWIC will seat in an EHIC without the use of an adapter  card.
https://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
In the PDF above you can see your card being supported by ISR G2 routers.
I hope this helps you!
Cheers,
Calin
Community Member
Thanks Paolo for your quick response and support.
Arshi
You are welcome, thanks for the nice rating and good luck!
Hello!
Cheers,
Calin
Community Member
Ddear Calin,
Thanks for your support, I have seen this document this morning but was not sure.
Arshi
Thanks for rating, really appreciate it!
Good luck and I hope to see you on this board again!
Calin
1787
