inter vlan configure in 3550 switch
i had configured like this...........
CAT3550# show running-config
Building configuration...
interface Vlan1
ip address 10.10.10.1 255.255.255.0
interface Vlan2
ip address 20.20.20.1 255.255.255.0
ip policy route-map pbr
interface Vlan3
ip address 30.30.30.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.10.10.2
ip classless
ip http server
access-list 10 permit 20.20.20.0 0.0.0.255
route-map pbr permit 10
match ip address 10
set ip next-hop 30.30.30.2
Re: inter vlan configure in 3550 switch
Hi Arup,
With this configuration, any packet that is coming into the switch from the 20.20.20.0/24 subnet (vlan2), will be sent out to next hop 30.30.30.2 through interface vlan3.
Is this what you want?
Istvan
Istvan
just i want vlan 2 will admin vlan which will access all vlan .how i can do it
Hi Arup,
From interface vlan2 remove the "ip policy route-map" command.
This way vlan2 will access all other vlans within this switch, supposed ip routing is enabled.
Cheers:
Istvan
hi Istvan....
changed it but still not working...
configure like this....
interface Vlan1
interface Vlan2
interface Vlan3
ip classless
ip http server
end
have you any configure which is my desire
Hi Arul,
Please remove "ip policy route-map" from vlan2.
The commands for this are
conf t
interface vlan2
no ip policy route-map pbr
Also, please enable ip routing:
conf t
ip routing
Cheers:
Istvan
111
