10-21-2008 09:50 PM - edited 03-04-2019 12:01 AM
hi expert
i want to configure inter vlan configure in 3550 switch.i had configure but not working could you guide me to configure it
10-21-2008 10:09 PM
Hi Arup,
Can you post what you have configured so far.
Istvan
10-21-2008 10:16 PM
hi Istvan
thnx for your reply but this switch is client end i can't access it...
i hda configure
* f0/1 is trunk port
*f0/2,f0/3,f0/4 ,f0/5 switch port access vlan 1,vlan 2,vlan 3,vlan 4,vlan 5
*each vlan assign different ip address
vlan 1-192.168.10.1 255.255.255.0
vlan 2-192.168.20.1 255.255.255.0
vlan 3-192.168.30.1 255.255.255.0
vlan 4-192.168.40.1 255.255.255.0
vlan 5-192.168.50.1 255.255.255.0
*and i rout 0.0.0.0 0.0.0.0 192.168.100.1(server gateway)
10-21-2008 10:23 PM
Hi Arup,
I don't quite understand how you want to configure it if you can't access it.
If you have access to it, use the "show ip route" command to check if you have the routing table.
If you don't have the routing table, you should enable ip routing using the "ip routing" global config command.
Cheers:
Istvan
10-21-2008 10:31 PM
i had configured ip route 0.0.0.0 0.0.0.0 192.168.100.1(server gateway)
10-21-2008 11:22 PM
hi, you have to configure SVI ports in order for intervlan routing worked in 3550. for this you have to assign ip address to every vlan interface. e.g interface vlan 1
ip address w.x.y.z subnet mask
interface vlan 2
ip address a.b.c.d subnet mask
10-21-2008 11:30 PM
Hi Arup,
Is routing working now between the vlans?
If not, please post the output of "show ip route" command.
Istvan
