Inter-vlan routing question (help)
Dear Sir,
I know that I can setup ISL trunk between a switch and a router for inter-vlan routing with subinterface on router. However, if I am connecting two routers back to back, can I still setup subinterface with ISL trunk on the link between two routers ?
thx
Eric
1 REPLY
Re: Inter-vlan routing question (help)
Hello Eric,
The answer is simple: Yes you can.
Thereby I must say that I do not see any practical advantage in doing it.
What are you trying to achieve with this setup?
Leo
110
