06-13-2006 01:36 AM - edited 03-03-2019 12:59 PM
wiil any body plz explain me how to do inter vlan routing in 3550 as if i ve config vlans in 2950
Solved! Go to Solution.
06-13-2006 01:48 AM
Dear imran,
Inter Routin routing used with MLS switches to route between different vlans, the interface VLAN ip address must be belong to the same subnet that the hosts on the vlan area using which then will be used as GW address for all vlan members.
CA3550(config)#vlan 600
CA3550(config-vlan)#name blabla
CA3550(config-if)#interface f0/1
CA3550(config-if)#switchport
CA3550(config-if)#switchport mode access
CA3550(config-if)#switchport access vlan 600
CA3550(config-if)#exit
CA3550(config-if)#interface vlan600
CA3550(config-if)#ip address 10.0.0.1 255.255.255.0
Best Regards,
Mounir Mohamed
06-13-2006 01:42 AM
HI imran.
Fisrt verify weather all the trunk configurations are working properly between the switches.
And on 3550 u have to create SVI's for each vlan u have defined,
For eg
interface vlan
ip address
and may this link will help u .
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Mahmood
06-13-2006 01:51 AM
Hi Imran,
In addition to above post remember to enable "ip routing" command on global config mode because it is disable on 3550 switch and till the time it is disable intervlan routing or normal routing will not work.
Once you enable "ip routing" you will be able to see all your vlans (logical interfaces are necessary) in your routing table as directly connected and intervlan rotuting will start working.
Ankur
06-13-2006 02:06 AM
Thanks mehmood for ur valuable help i ll go throug the link which u ve provided me
06-13-2006 01:48 AM
Dear imran,
Best Regards,
Mounir Mohamed
06-13-2006 02:03 AM
hi imran,
here you need to creat the multiple svi...like this
config)#interface vlan XXX
config-if)# ip address 10.1.x.x 255.x.x.x
config-if)# no shut
config)#interface vlan yyy
config-if)# ip address 10.2.x.x 255.x.x.x
config-if)# no shut
like this on switch 33550
hope this helps you
rate this post if it helps
regards
Devang
