08-08-2012 04:14 AM - edited 03-04-2019 05:12 PM
Hi.
Is there any ways to route between VRFs in one router asaide of using BGP, cross-connecting router physical interfaces or using tunnel interface(which is process-switched)?
08-08-2012 04:25 AM
No. The VRF are totally separated routing instances and unless some particular route leaking you need to consider the VRF like physically separated networks.
Alessio
08-08-2012 05:43 AM
Hello Utair,
you need to run BGP on the router and to have an address family ipv4 vrf name configured for each VRF.
Communication between VRFs can be build by working on route targets.
By adding an import command under VRF-A configuration routes of VRF-B can be imported in VRF-A routing table.
This is called extranet
see this recent thread about a selective extranet using export maps (route-maps used to perform selective route exchanges between two VRFs)
https://supportforums.cisco.com/message/3703348#3703348
Hope to help
Giuseppe
08-09-2012 03:23 AM
Problem with BGP is what we plan on using BGP for importing Internet routes from several ISPs and announce them our PI block (primary ISP and several backups).
I wanted to separate LAN routing in VRF and NAT LAN traffic using some internal interface with IP from PI block, so NAT sessions will remain valid on ISP switchover.
Right now i have just cross-connected two interfaces on same router and NATing on LAN VRF side.
I have tried to use loopbacks and gre tunnel technique, but performance degrade awfully.
