Interface Card and Network Module
what is the difference between Interface Cared and Network Module?
I want to terminate 16 T1 as the 3800 series router will it be possible to have 16 or more T1 termination at the same router 3800?
Bronze
Re: Interface Card and Network Module
No I think its only Low speed WAN aggregation (up to 128 Kbps).
Have a look at this link:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b8b.html
Bjornarsb
Hi Dangal
As far as the slots are concerned you can easily have 16 T1 connections.
You have the options of 4 WIC slots and 4 NME slots where you can place 4 WIC-2T and on the NME slots you can place the combinations of NM-2W and wic cards on that ..
By doing so i feel you will be able to connect 16 T1 lines onto your Cisco 3845 router..
regds
224
