08-21-2013 09:30 PM - edited 03-04-2019 08:50 PM
Hello Everyone,
First of all I would like to state that I'm far from being a QoS especialist. I need someone to shed some light on the following issue;
The below configuration is applied to a WAN link, and the interface is dropping packets on the Default class even when the link is being used at half of its capacity, specifically when the traffic is above 1424 kbps the dropping starts. What could be wrong here?
interface FastEthernet0/1.2
bandwidth 4096
encapsulation dot1Q 2
service-policy output ShapingD
policy-map ShapingD
class class-default
shape average 4096000 40960 40960
service-policy QoS_Out
policy-map QoS
class Mgmt_Out
bandwidth 16
set ip precedence 6
class Voice
priority 1024
police 1024000 192000 384000 conform-action set-prec-transmit 5 exceed-action drop violate-action drop
class Platinum
bandwidth 1536
random-detect
police 1536000 288000 576000 conform-action set-prec-transmit 3 exceed-action set-prec-transmit 3 violate-action set-prec-transmit 3
class Silver
bandwidth 96
random-detect
police 96000 18000 36000 conform-action set-prec-transmit 1 exceed-action set-prec-transmit 1 violate-action set-prec-transmit 1
class Default
bandwidth 1424
random-detect
police 1424000 267000 534000 conform-action set-prec-transmit 0 exceed-action set-prec-transmit 0 violate-action set-prec-transmit 0
Solved! Go to Solution.
08-22-2013 05:39 AM
As far as I can see, the policer under class Platinum does nothing at all.
Match: ip precedence 3
It "remarks" conforming, exceeding and violating traffic to ip prec 3 (which is already marked as prec 3).
We can see WRED-drops and taildrops as well in that class.
In order to reduce the taildrops, you may want to remark violating traffic to 0.
WRED is enabled by the random-detect command.
If it doesn't meet your requirments, you can disable it (no random-detect) or you can change the minimum and maximum threshold:
precedence <0-7>
Rolf
P.S.: WRED starts dropping TCP when the min-threshold of the queue is reached. This is done to force the endstation to reduce the window size (TCP has kind of an aggressive nature in terms of occupying bandwidth).
08-22-2013 07:15 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What's wrong? Likely you have bursts that are invisible to your load usage.
You're shaping at 4 Mbps. A "50% load" across a minute might be caused by sending at a 2 Mbps rate across the whole minute, or sending at 8 Mbps for 15 of the 60 seconds (and not sending for the remaining 45 seconds). The former wouldn't queue, but the latter would. For the latter, queue capacity is exceeded, you'll have drops. Again, important to note both will show as just 50% utilization across one minute.
In you detail stats, you have RED drops and tail drops. This would indicate bursts that are invisible to your load stats.
If the bursts are indeed transitory, simple solution is often just to increase queue settings. Your drop rate will likely decrease although you increase transitory latency.
BTW, your device's default values for RED, I believe, were "designed" for T1/E1 bandwidth. As you have 4 Mbps, they could be increased. (Also, IMO, the default values are not optimal even for T1/E1. Further, optimal values for RED can be difficult to "find"; so much so, I often recommend RED not be used.)
08-22-2013 12:58 AM
Hi Ruben,
I'm neither a QoS expert and there's one thing I don't understand about the child policy-map "QoS": For the classes Platinum, Silver and Default you have policers which have the same action (rewrite packet precedence to 3/1/0 and send it) for conforming, exceeding and violating traffic. What is the reason for doing so?
Could you please provide the output of show policy-map interface FastEthernet0/1.2 ?
Rolf
08-22-2013 01:58 AM
Hi Fischer,
As far as I know the intention for this configuration is to lower the precedence of the packets as the traffic exceeds the bandwidth allocated for each class until reach 0. That's exactly why I don't get why the packet are dropped.
Service-policy output: ShapingD
Class-map: class-default (match-any)
20084361 packets, 27984912474 bytes
5 minute offered rate 431000 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
4096000/4096000 10240 40960 40960 10 5120
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 19939900 2008019924 11186829 3113358735 no
Service-policy : QoS
Class-map: Mgmt_Out (match-any)
15560 packets, 1096499 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip precedence 6 7
5 minute rate 0 bps
Match: access-group 160
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 137
Bandwidth 16 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 1294/90200
(depth/total drops/no-buffer drops) 0/0/0
QoS Set
precedence 6
Packets marked 15560
Class-map: Voice (match-any)
0 packets, 0 bytes
Match: ip precedence 5
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 136
Bandwidth 1024 (kbps) Burst 25600 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
police:
cir 1024000 bps, bc 192000 bytes, be 384000 bytes
conformed 0 packets, 0 bytes; actions:
set-prec-transmit 5
exceeded 0 packets, 0 bytes; actions:
drop
violated 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps, violate 0 bps
Class-map: Platinum (match-any)
9561579 packets, 13259511619 bytes
5 minute offered rate 261000 bps, drop rate 0 bps
5 minute rate 261000 bps
Queueing
Output Queue: Conversation 138
Bandwidth 1536 (kbps)
(pkts matched/bytes matched) 5007974/7152261088
(depth/total drops/no-buffer drops) 0/69410/0
exponential weight: 9
mean queue depth: 0
class Transmitted Random drop Tail drop Minimum Maximum Mark
pkts/bytes pkts/bytes pkts/bytes thresh thresh prob
0 0/0 0/0 0/0 20 40 1/10
1 0/0 0/0 0/0 22 40 1/10
2 0/0 0/0 0/0 24 40 1/10
3 9492169/13159991239 53364/76487653 16046/23032727 26 40 1/10
4 0/0 0/0 0/0 28 40 1/10
5 0/0 0/0 0/0 30 40 1/10
6 0/0 0/0 0/0 32 40 1/10
7 0/0 0/0 0/0 34 40 1/10
rsvp 0/0 0/0 0/0 36 40 1/10
police:
cir 1536000 bps, bc 288000 bytes, be 576000 bytes
conformed 7895691 packets, 10865709422 bytes; actions:
set-prec-transmit 3
exceeded 1242527 packets, 1785126424 bytes; actions:
set-prec-transmit 3
violated 423361 packets, 608675773 bytes; actions:
set-prec-transmit 3
conformed 235000 bps, exceed 13000 bps, violate 0 bps
Class-map: Silver (match-any)
0 packets, 0 bytes
Match: ip precedence 1
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 139
Bandwidth 96 (kbps)
mean queue depth: 0
3 0/0 0/0 0/0 26 40 1/10
police:
cir 96000 bps, bc 18000 bytes, be 36000 bytes
set-prec-transmit 1
set-prec-transmit 1
set-prec-transmit 1
10507222 packets, 14724304356 bytes
5 minute offered rate 149000 bps, drop rate 0 bps
Match: any
Queueing
Output Queue: Conversation 140
Bandwidth 1424 (kbps)
(pkts matched/bytes matched) 6322015/9052997661
(depth/total drops/no-buffer drops) 0/75051/0
mean queue depth: 0
0 10432171/14616735962 73447/105269524 1604/2298870 20 40 1/10
police:
cir 1424000 bps, bc 267000 bytes, be 534000 bytes
conformed 7856284 packets, 10915180974 bytes; actions:
set-prec-transmit 0
exceeded 1746711 packets, 2509195690 bytes; actions:
set-prec-transmit 0
violated 904198 packets, 1299925836 bytes; actions:
set-prec-transmit 0
conformed 123000 bps, exceed 14000 bps, violate 0 bps
08-22-2013 03:31 AM
So we can see WRED-drops for the Platinum and Default classes:
(53364/9492169 = 0,56%)
(73447/10432171 = 0,7%)
Are you familiar with the concept of WRED congestion avoidance?
Rolf
08-22-2013 04:01 AM
Thanks Fischer,
I'm not familiarized with WRED, but how can I avoid the early drop of the packets?
08-22-2013 03:49 AM
Please state router model and IOS version by posting "show version" as it should always be done when reporting problems.
08-22-2013 03:59 AM
Hi Paolo,
The Router is a 1841, C1841-SPSERVICESK9-M, Version 12.4(23b)
08-22-2013 04:03 AM
Update IOS and check again.
08-22-2013 04:20 AM
It is also happening in these two other routers
CISCO2911, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M6
Cisco 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(24)T3
I thinks this is more a configuration issue.
08-22-2013 05:01 AM
You can try reducing the complexity of you policy-map until the results are met.
08-22-2013 05:39 AM
precedence <0-7>
Rolf
08-22-2013 05:58 AM
This is weird, I was reading about how to monitor WRED and this is the outputs that I got
#sh queueing random-detect
Current random-detect configuration:
#sh queue fastEthernet 0/1
'Show queue' not supported with FIFO queueing.
#sh int fa0/1 | in Queueing
Queueing strategy: fifo
It seems like WRED is not enable
The output of th last command should look something like this
Queueing strategy: random early detection (WRED)
08-22-2013 06:15 AM
That's a long story ...
In former times QoS was configured under every interface. Nowadays we use the MQC (modular QoS CLI).
With MQC, we use the show policy-map interface command. You can see the most interesting lines (regarding WRED) in my second posting.
08-22-2013 07:15 AM
Disclaimer
Posting
08-22-2013 09:05 PM
Thanks a lot to both Fischer and Joseph, will try to play with the WRED thresholds and see what happen, make a lot of sense since the graphs are showing peaks of transitory traffic and also peaks of transitory latency.
