interface modules
hi friends,
i have 2811 router it is having 2 interfaces e0,e1.i am having ip connect line totally 3 lines so i need additional ethernet interface cards .which is the card is need to use and part number and how many card we can put in 2811 router.....
plz help me in this
tanks
Hall of Fame Super Gold
Re: interface modules
You don't necessarily need more physical interfaces. You can use any switch with vlans and use 802.1q subinterfaces.
Super Bronze
Agree with Paolo, that you might want to consider using subinterfaces on one or both your existing FastEthernet interfaces. However, for "routed" Ethernet options, see: http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html#ethernetrouted. Also, you can route using Ethernet switch modules via VLANs, so you might also want to examine: http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html#esm
99
