Community Member
Intermitently can not reach one subnet from WAN
A few times a day we can not reach one subnet across one of our WAN links. the traceroutes die at our WAN router before it hits our core router. I cleared the arp table on the 2651XM WAn router and was able to ping. I am not sure if it was by chance that it happened at the same time I cleared the arp table or not. Any ideas what might be causing it? If I log into the router I can ping the subnet but from the the sites it dies at the outside interface of our 2651xm
Silver
Re: Intermitently can not reach one subnet from WAN
Could you paste running config on your 2651?
Community Member
version 12.3
service timestamps debug datetime
service timestamps log datetime
service password-encryption
boot-start-marker
boot system flash c2600-is-mz.122-8.t10.bin
boot system flash:c2600-is-mz.123-22.bin
boot-end-marker
no logging console
clock timezone CST -6
clock summer-time CDT recurring
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
ip flow-cache timeout active 1
ip cef
policy-map WFQ
class class-default
fair-queue
interface FastEthernet0/0
no ip address
no ip mroute-cache
shutdown
speed auto
half-duplex
interface FastEthernet0/1
ip address 192.234.179.127 255.255.255.0
no ip redirects
ip route-cache flow
no ip mroute-cache
speed 100
full-duplex
arp timeout 1800
interface ATM1/0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
ima-group 3
no scrambling-payload
cablelength short 399
interface ATM1/1
no ip address
no ip mroute-cache
ima-group 3
interface ATM1/2
no ip address
no ip mroute-cache
shutdown
interface ATM1/3
no ip address
no ip mroute-cache
shutdown
interface ATM1/IMA3
ip address 192.168.1.5 255.255.255.252
no ip route-cache cef
no ip route-cache
atm uni-version 3.1
no atm auto-configuration
no atm address-registration
no atm ilmi-enable
ima differential-delay-maximum 50
service-policy output WFQ
pvc 0/101
protocol ip 192.168.1.6 broadcast
vbr-nrt 2700 2700 1
oam-pvc manage
encapsulation aal5snap
ip default-gateway 192.234.179.110
no ip http server
ip flow-export source FastEthernet0/1
ip flow-export version 5
ip flow-export destination 192.234.179.173 9996
ip classless
ip route 0.0.0.0 0.0.0.0 192.234.179.121
ip route 172.21.0.0 255.255.255.128 192.168.1.6
ip route 192.168.13.0 255.255.255.0 192.168.1.6
ip route 192.168.16.0 255.255.255.0 192.168.1.6
ip route 192.168.17.0 255.255.255.0 192.168.1.6
ip route 192.168.18.0 255.255.255.0 192.168.1.6
ip route 192.168.22.0 255.255.255.0 192.168.1.6
ip route 192.168.26.0 255.255.255.0 192.168.1.6
ip route 192.168.41.0 255.255.255.0 192.168.1.6
ip route 192.168.42.0 255.255.255.0 192.168.1.6
ip route 192.168.43.0 255.255.255.0 192.168.1.6
ip route 192.168.44.0 255.255.255.0 192.168.1.6
ip route 192.168.68.0 255.255.255.0 192.168.1.6
ip route 192.234.189.0 255.255.255.0 192.168.1.6
ip route 192.234.190.0 255.255.255.0 192.168.1.6
ip route 192.234.192.0 255.255.255.0 192.168.1.6
ip route 192.234.193.0 255.255.255.0 192.168.1.6
ip route 192.234.194.0 255.255.255.0 192.168.1.6
ip route 192.234.195.0 255.255.255.0 192.168.1.6
ip route 192.234.201.0 255.255.255.0 192.168.1.6
ip route 192.234.203.0 255.255.255.0 192.168.1.6
ip route 192.234.204.0 255.255.255.0 192.168.1.6
ip route 192.234.205.0 255.255.255.0 192.168.1.6
ip route 192.234.209.0 255.255.255.0 192.168.1.6
ip route 192.234.210.0 255.255.255.0 192.168.1.6
ip route 192.234.216.0 255.255.255.0 192.168.1.6
Community Member
have you taken a look at your atm interface? any errors? do a 'show log' on the router..anything stands out as the potential cause of the problem?
Community Member
I disabled CEF on friday and so far everything seems to be working. Why would CEF be causing this issue if that is really the cause?
Community Member
sure, it seems a kind of transmition issue. Check your links out and provide an output of your log.
rgds
Community Member
what logs do you need?
102
