internal return traffic blocked by external int ACL
TRO Group
   Hi guys
We are getting return traffic from our internal subnet blocked by our outside interface ACL (dialer 0).  If i remove the ACL (OUTSIDE_IN) from the outside interface internal hosts can access the internet etc fine.  As soon as the OUTSIDE_IN ACL is applied to the outside interface it blocks their traffic.
I entered the below commands and applied the inspect policy to the internal interface fa0/0.  This now allows ping to go through to external websites successfully but all other traffic is blocked.  This is even the case if i remove the internal interface ACL (TRUST_OUT)
ip inspect name traffic tcp
ip inspect name traffic udp
ip inspect name traffic icmp
I am at a loss here are you able to assist?
See below config.
#show run
Building configuration...
Current configuration : 5048 bytes
version 12.4
hostname
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.124-22.YB8.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1 192.168.100.59
ip dhcp excluded-address 192.168.100.253 192.168.100.254
ip dhcp pool Internal_Network_DHCP_Pool
   network 192.168.100.0 255.255.252.0
   default-router 192.168.100.254
   dns-server 192.168.100.254
   lease 3
no ipv6 cef
voice-card 0
username admin privilege 15 secret 5 $1$E.Pe$V1UAU5P0m1S8ObtPXGNFD.
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 192.168.100.254 255.255.252.0
ip access-group TRUST_OUT in
ip inspect traffic in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/33
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface BRI0/0/0
no ip address
encapsulation hdlc
shutdown
interface Serial0/1/0
no ip address
shutdown
no fair-queue
clock rate 2000000
interface Dialer0
mtu 1492
ip access-group OUTSIDE_IN in
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1400
dialer pool 1
no cdp enable
ppp chap hostname
ppp chap password
ppp ipcp dns request accept
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list ACL-NAT-Internal interface Dialer0 overload
ip access-list extended ACL-NAT-Internal
permit ip 192.168.100.0 0.0.3.255 any
ip access-list extended OUTSIDE_IN
permit tcp any host 192.168.100.30 eq 5150
permit tcp any host 192.168.100.30 eq 5160
permit tcp any host 192.168.100.30 eq 8080
ip access-list extended TRUST_OUT
permit tcp 192.168.100.0 0.0.3.255 any eq www
permit tcp 192.168.100.0 0.0.3.255 any eq 443
permit tcp 192.168.100.0 0.0.3.255 any eq domain
permit udp 192.168.100.0 0.0.3.255 any eq domain
permit icmp 192.168.100.0 0.0.3.255 any echo
permit tcp 192.168.100.0 0.0.3.255 host 192.168.100.254 eq telnet
access-list 1 permit 192.168.100.0 0.0.3.255
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
line con 0
privilege level 15
login local
line aux 0
line vty 0 4
privilege level 15
login local
scheduler allocate 20000 1000
end
8 Replies 8
John Blakley
You should try moving your inspect to the outside interface instead of on the lan. On your Dialer, put "
ip inspect traffic out" and see if that resolves the issue.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Hi John
I tried this but the same i am afraid.
Jon
cadet alain
Can you add ip inspect log drop-pkt in global config and deny ip any any log in  your  OUTSIDE_IN access-list
Then try to browse www.google.com from a client and post any log output as well as sh ip nat trans | x.x.x.x where x.x.x.x is the IP of the client and sh ip inspect session and sh access-list
Alain
Hi Alain
I will give this a try and post the output.  I will not be able to try today but will come back here with the results asap.
Thank you for your response.
Jonny
Hi Alain
Sorry for taking so long to come back, workload has intervened.
here is a snippet of output of when i try and browse to google from an internal host
Jan 29 11:14:14.267: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 194.72.0.98(53) -> 86.147.189.53(63262), 1 packet
*Jan 29 11:14:15.271: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 194.72.0.98(53) -> 86.147.189.53(52520), 1 packet
*Jan 29 11:14:16.283: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 194.72.0.98(53) -> 86.147.189.53(55671), 1 packet
*Jan 29 11:14:17.319: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 62.6.40.178(53) -> 86.147.189.53(58992), 1 packet
*Jan 29 11:14:20.323: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 62.6.40.178(53) -> 86.147.189.53(61185), 1 packet
*Jan 29 11:14:22.307: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 194.72.0.98(53) -> 86.147.189.53(57653), 1 packet
*Jan 29 11:14:23.327: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 62.6.40.178(53) -> 86.147.189.53(63262), 1 packet
*Jan 29 11:14:24.959: %SEC-6-IPACCESSLOGP: list OUTSIDE_IN denied udp 194.72.0.98(53) -> 86.147.189.53(53654), 1 packet
CISCO-2811#sh access-lists
Standard IP access list 1
    10 permit 192.168.100.0, wildcard bits 0.0.3.255
Extended IP access list ACL-NAT-Internal
    10 permit ip 192.168.100.0 0.0.3.255 any (44 matches)
Extended IP access list OUTSIDE_IN
    10 permit tcp any host 192.168.100.30 eq 5150
    20 permit tcp any host 192.168.100.30 eq 5160
    30 permit tcp any host 192.168.100.30 eq 8080
    40 deny ip any any log (1892 matches)
Extended IP access list TRUST_OUT
    10 permit tcp 192.168.100.0 0.0.3.255 any eq www (15334 matches)
    20 permit tcp 192.168.100.0 0.0.3.255 any eq 443 (355 matches)
    30 permit tcp 192.168.100.0 0.0.3.255 any eq domain
    40 permit udp 192.168.100.0 0.0.3.255 any eq domain (323 matches)
    50 permit icmp 192.168.100.0 0.0.3.255 any echo
    60 permit tcp 192.168.100.0 0.0.3.255 host 192.168.100.254 eq telnet
    70 permit udp any any eq bootps (6 matches)
This is the output of show Access-lists
Show ip nat trans displays nothing im afraid.
Show ip inspect sessions displays nothing also
Can you repost your current config that you are using when you see denied messages in your last post.
Jon
I don't think your inspects are working, or it would at least seem that way. You can leave the inspect inbound on the lan side interface, but can you try a couple of other things?
Try adding "ip inspect name traffic dns" (True, inspecting udp should fix it, but maybe it's an ios issue?)
Try removing "ip inspect traffic in" from the interface and then reapply it.
Then timeouts happen pretty quick for the inspect table. Maybe you should increase it temporarily to see if you are getting entries in your inspect table:
ip inspect name traffic dns timeout 30
Then try to browse from  a host again and do a "sh ip inspect session". Hopefully, you should see something. I labbed it up with a config like yours and I get sessions just fine:
R2#sh ip inspect sess
Established Sessions
Session 671484A0 (192.168.12.1:8)=>(192.168.23.3:0) icmp SIS_OPEN
Session 67148768 (192.168.12.1:59144)=>(192.168.23.3:53) dns SIS_OPEN
R2#
R2's config:
ip inspect name firewall udp
ip inspect name firewall icmp
ip address 192.168.12.2 255.255.255.0
ip access-group 101 in
ip nat inside
ip inspect firewall in
speed 100
full-duplex
ip address 192.168.23.2 255.255.255.0
ip access-group 102 in
ip nat outside
speed 100
full-duplex
end
Extended IP access list 101
    10 permit udp 192.168.12.0 0.0.0.255 any eq domain (12 matches)
    20 permit icmp any any (45 matches)
Extended IP access list 102
    5 permit tcp any host 192.168.23.2 eq www
    10 deny ip any any (9 matches)
My nat config is just allowing 192.168.12.0/24 out with fa0/0 being the inside interface.
HTH,
John
Hi Jon
Full config at top of thread
