Internet and Remote network
daveporter123
i have one local site with the LAN (172.16.0.0) and local site is connected witht the remote site, both the ends are connected with ADSL and having router at both the site. Remote site having LAN (10.0.0.0) now i want to access the remote LAN hosts as well as internet at the same time from local office...
LAN 172.16.0.0---routerA----ADSL----RouterB---LAN 10.0.0.0
how can i do this?
For GRE Tunnel
Office Router WAN Public IP Address = a.b.c.2, Gateway = a.b.c.1
Remote Router WAN Interface Public IP Address = w.x.y.2, Gateway w.x.y.1
Since you're using 72.16.0.0/12 and 10.0.0.0/8, we will use 192.168.0.0/16 fro Tunnel IP
1. Office
interface tunnel0
ip address 192.168.0.1 255.255.255.252
tunnel source a.b.c.2
tunnel destination w.x.y.2
keepalive 5 4
ip mtu 1500
ip subnet-zero
ip classless
ip route 0.0.0.0 0.0.0.0 a.b.c.1
ip route 10.0.0.0 255.0.0.0 tunnel0
2. Remote
interface tunnel0
ip address 192.168.0.2 255.255.255.252
tunnel source w.x.y.2
tunnel destination a.b.c.2
keepalive 5 4
ip mtu 1500
ip subnet-zero
ip classless
ip route 0.0.0.0 0.0.0.0 w.x.y.1
ip route 172.0.0.0 255.240.0.0 tunnel0
15 Replies 15
hoogen_82
Level 4
Level 4
Hi Dave
This link is specific to your requirement
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800949ef.shtml
Hoogen
Do rate if this helps out :)
i want simple configuration
will you please give me some basic confiuration?
1. Does both site (office and remote) has a static assigned Public IP Address from your internet provider(s)?
2. Does both router IOS capable of running IPSEC and or IP GRE?
yes,
i had only single static public IP address.
and IOS is capable of IP GRE.
is it possible to establish gre tunnel between both the site and forwarding only private ip address data to the tunnel using static route and for othere internet traffice we can use that default router which is pointing to the real ip of interface or to the default gateway of the isp.
Yes its possible. For example you build a GRE Tunnel0, your routing will be like this
Office (RouterA):
ip route 0.0.0.0 0.0.0.0 ip_address_of_isp_router_facing_routerA
ip route 10.0.0.0 255.0.0.0 Tunnel0
Remote (RouterB):
ip route 0.0.0.0 0.0.0.0 ip_address_of_isp_router_facing_routerB
ip route 172.16.0.0 255.240.0.0 Tunnel0
You can use the link previously provided to build GRE Tunnel, else if you want a configuration sample that suit your environment, we need you to post your configuration (remove confidential information like password, and change the first and second octet of the public ip address to xxx.yyy)
thank you expert,
right now i am configuring the same using GRE but i thing in LAN switching forum RAJ replied me with IPSEC so i will try to move on it slowly. but your advise help me a lot in configuration thank you very much.
I really appriciate your help and support, i also appriciate all the exper and member of the discussion forum for their knowledge sahring.
thank you very much again
Since your router does not support IPSEC, you can try GRE first. Once its working, you can justify to put some $$$ to upgrade to IOS that support IPSEC so that the tunnel is secure :)
when confiugring GRE? what ip address i should use to configure the tunnel interface ip address? it must be private ip address and i should use tunnel source as the Global IP address which is already configure to my one the the interface which is facing towards the ISP? am i right or wrong?
please provide me both end solution as well as same for IP sec VPN...
Use as source the wan interface facing internet configured with public ip address of the local router. Use as destination the configured public ip address of the wan interface facing internet of the remote router.
It would be easier if you provide us the configuration of at least the interface facing internet for both routers (including routing configuration) as there is a configuration difference for dsl service for some countries.
hi medan,
i dont how any configuration but i have to start configure the both end router after two days. so please send me some example's configuration.
For GRE Tunnel
1. Office
interface tunnel0
keepalive 5 4
ip mtu 1500
ip subnet-zero
ip classless
2. Remote
interface tunnel0
keepalive 5 4
ip mtu 1500
ip subnet-zero
ip classless
For IPSEC
When you already have the IOS that is capable of running IPSEC, you need to remove the GRE Tunnel first.
1. Office
no interface tunnel0
no ip route 10.0.0.0 255.0.0.0 tunnel0
crypto isakmp policy 3
authentication pre-share
crypto isakmp key trinity address w.x.y.2 no-xauth
crypto ipsec transform-set NEO esp-des esp-sha-hmac
crypto map TheMatrix 1 ipsec-isakmp
set peer w.x.y.2
set transform-set NEO
set pfs group1
match address 101
access-list 101 permit ip 172.16.0.0 0.240.255.255 10.0.0.0 0.255.255.255
interface wan_interface_facing_internet
ip address a.b.c.2 255.255.255.252
2. Remote
no ip route 172.16.0.0 255.240.0.0 tunnel0
crypto isakmp key trinity address a.b.c.2 no-xauth
set peer a.b.c.2
set pfs group1
match address 101
access-list 101 permit ip 10.0.0.0 0.255.255.255 172.16.0.0 0.240.255.255
ip address w.x.y.2 255.255.255.252
