Inverse Multiplexing over ATM - IMA
nedian123
using E1s spanned over long(1000km) distance with IMA makes problem i.e. causing drops in packets in this case maximum differential delay being used is 25ms i have also tested the same thing over greater max. differential delay(100ms).
But using the same E1s without IMA causes no problem but this is not a solution & causes lots of overhead, i've to exploit IMA.....
One more thing using E1s in IMA spanned over short distances are working perfect.
Any comments would be helpful
Cheers,
Akhtar
pradeepde
Level 5
Level 5
