IOS and Syslog-NG
drummond.r
I have been trying to setup logging via tcp on syslog-ng. all the messages come in fine via udp, but when i configure a tcp source, assign it to the syslog-ng target, etc, then configure the router, i don't get any events. i can see the packets coming in via tcp dump, but syslog-ng won't collect anything. am i missing something. my logging config is below....
logging buffered 4096 informational
logging origin-id hostname
logging source-interface Serial1.1
logging host 192.168.101.150 transport tcp port 5014
jtalbaugh
Possibly the logging trap command. This can be set to several different levels so set to what best suits your needs.
an example of my basic config below:
logging on
logging #.#.#.#
logging source-interface Loopback0
logging trap notificati
doesn't seem to help; here is the output from a show log:
Syslog logging: enabled (1 messages dropped, 0 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level informational, 117 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
No active filter modules.
Trap logging: level notifications, 173 message lines logged
Logging to 192.168.101.153(global) (tcp port 5014, audit disabled, link up), 4 message lines logged, xml disabled,
filtering disabled
