08-01-2013 06:48 AM - edited 03-04-2019 08:37 PM
I noticed the ISO had disappeared from flash and I get this error on booting:.
%Error opening c2800nm-adventerprisek9-mz.124-11.XJ4.bin (file not found)
The router boots ok and works great, I have lots of stuff for my CME in there and I do not feel like formatting the flash...
Any idea how I can see the IOS so I can remove it and upgrade it ? I even tried to FTP the c2800nm-adventerprisek9-mz.124-11.XJ4.bin to an outside server, it fails after 33MB.
I do not have boot image secure as the file is "missing" , the router does not allow the command to go thru.
Any help is appreciated.
As you see: lines 1 and 2 are missing, it starts at "3"
guess 1 or 2 must be the line for IOS
2811#sh flash
3 0 Jan 31 2013 13:22:30 -05:00 bacdprompts
4 18836 Jan 31 2013 13:22:32 -05:00 bacdprompts/app-b-acd-2.1.2.2-ReadMe.txt
5 75650 Jan 31 2013 13:22:32 -05:00 bacdprompts/en_bacd_allagentsbusy.au
6 83291 Jan 31 2013 13:22:32 -05:00 bacdprompts/en_bacd_disconnect.au
7 63055 Jan 31 2013 13:22:34 -05:00 bacdprompts/en_bacd_enter_dest.au
8 37952 Jan 31 2013 13:22:34 -05:00 bacdprompts/en_bacd_invalidoption.au
9 496521 Jan 31 2013 13:22:38 -05:00 bacdprompts/en_bacd_music_on_hold.au
10 123446 Jan 31 2013 13:22:38 -05:00 bacdprompts/en_bacd_options_menu.au
11 42978 Jan 31 2013 13:22:40 -05:00 bacdprompts/en_bacd_welcome.au
12 34794 Jan 31 2013 13:22:40 -05:00 bacdprompts/en_bacd_xferto_operator.au
13 19566 Jan 31 2013 13:22:40 -05:00 CME42-full-readme-v.1.0.txt
14 0 Jan 31 2013 13:22:40 -05:00 CP7921G-1.0.3
15 871 Jan 31 2013 13:22:42 -05:00 CP7921G-1.0.3/CP7921G-1.0.3.LOADS
16 1868518 Jan 31 2013 13:22:50 -05:00 CP7921G-1.0.3/APPS-1.0.3.SBN
17 1461170 Jan 31 2013 13:22:56 -05:00 CP7921G-1.0.3/GUI-1.0.3.SBN
18 2078210 Jan 31 2013 13:23:04 -05:00 CP7921G-1.0.3/SYS-1.0.3.SBN
19 893001 Jan 31 2013 13:23:08 -05:00 CP7921G-1.0.3/TNUX-1.0.3.SBN
20 2196478 Jan 31 2013 13:23:18 -05:00 CP7921G-1.0.3/TNUXR-1.0.3.SBN
21 1300663 Jan 31 2013 13:23:24 -05:00 CP7921G-1.0.3/WLAN-1.0.3.SBN
22 0 Jan 31 2013 13:23:24 -05:00 Desktops
23 0 Jan 31 2013 13:23:24 -05:00 Desktops/320x212x12
24 131470 Jan 31 2013 13:23:26 -05:00 Desktops/320x212x12/CampusNight.png
25 80565 Jan 31 2013 13:23:26 -05:00 Desktops/320x212x12/CiscoFountain.png
26 138278 Jan 31 2013 13:23:28 -05:00 Desktops/320x212x12/Fountain.png
27 109076 Jan 31 2013 13:23:30 -05:00 Desktops/320x212x12/MorroRock.png
28 108087 Jan 31 2013 13:23:30 -05:00 Desktops/320x212x12/NantucketFlowers.png
29 10820 Jan 31 2013 13:23:30 -05:00 Desktops/320x212x12/TN-CampusNight.png
30 9657 Jan 31 2013 13:23:32 -05:00 Desktops/320x212x12/TN-CiscoFountain.png
31 7953 Jan 31 2013 13:23:32 -05:00 Desktops/320x212x12/TN-Fountain.png
32 7274 Jan 31 2013 13:23:34 -05:00 Desktops/320x212x12/TN-MorroRock.png
33 9933 Jan 31 2013 13:23:34 -05:00 Desktops/320x212x12/TN-NantucketFlowers.png
34 628 Jan 31 2013 13:23:34 -05:00 Desktops/320x212x12/List.xml
35 0 Jan 31 2013 13:23:34 -05:00 gui
36 4802 Jan 31 2013 13:23:36 -05:00 gui/admin_user.html
37 657587 Jan 31 2013 13:23:38 -05:00 gui/admin_user.js
38 1602 Jan 31 2013 13:23:40 -05:00 gui/CiscoLogo.gif
39 619 Jan 31 2013 13:23:40 -05:00 gui/CME_GUI_README.TXT
40 953 Jan 31 2013 13:23:40 -05:00 gui/delete.gif
41 16344 Jan 31 2013 13:23:42 -05:00 gui/dom.js
42 864 Jan 31 2013 13:23:42 -05:00 gui/downarrow.gif
43 6146 Jan 31 2013 13:23:42 -05:00 gui/ephone_admin.html
44 4658 Jan 31 2013 13:23:44 -05:00 gui/logohome.gif
45 3724 Jan 31 2013 13:23:44 -05:00 gui/normal_user.html
-----------snip--------------------
Once the problem fixed, I would like to upgrade my IOS from c2800nm-adventerprisek9-mz.124-11.XJ4.bin to c2800nm-adventerprisek9-mz.124-20.YA2.bin
Solved! Go to Solution.
08-09-2013 01:36 PM
John,
Please let's get back to that software I have suggested. You have used it incorrectly, as you have selected your hard disk as the target. That is not what I had in mind - what I need is a file image of the CF card. Let's do it once again, here are the steps.
After starting the program, in the first screen, select the CF card just as you did and click on the Continue button. Then, in the target selection screen, double-click the FILE option in the list and insert the name of the file you want to save the image as. In the same file save window, select the type of image: "Raw image (dd image)". Then click on the Continue button again. In the next screen, it should not warn you about formatting a drive anymore, and after clicking on the START button, the CF card shall be stored as an image.
I understand that your issues may be solved with the new CF card but this is such an obscure error that I am extremely strongly interested in learning what really happened. Please be patient with me here and try to go over this exercise once again. Thank you!
Best regards,
Peter
08-01-2013 07:02 AM
does a dir flash:
You could try a delete flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin If you are just wanting to remove the file
08-01-2013 07:10 AM
Thank you, James,
Not really showing more.
c2800nm-adventerprisek9-mz.124-11.XJ4.bin is my production IOS, If I remove it, the router wont run...
Beside, I doutb I can remove it as the router does not see it.
2811#dir flash:
Directory of flash:/
3 drw- 0 Jan 31 2013 13:22:30 -05:00 bacdprompts
13 -rw- 19566 Jan 31 2013 13:22:40 -05:00 CME42-full-readme-v.1.0.txt
14 drw- 0 Jan 31 2013 13:22:40 -05:00 CP7921G-1.0.3
22 drw- 0 Jan 31 2013 13:23:24 -05:00 Desktops
35 drw- 0 Jan 31 2013 13:23:34 -05:00 gui
54 -rw- 496521 Jan 31 2013 13:23:52 -05:00 music-on-hold.au
55 drw- 0 Jan 31 2013 13:23:52 -05:00 phone
102 drw- 0 Jan 31 2013 13:27:34 -05:00 ringtones
136 drw- 0 Feb 21 2013 21:05:20 -05:00 its
128167936 bytes total (22663168 bytes free)
08-01-2013 09:20 AM
Thank you Peter,
As I stated in my original post,
Now I do no secure boot-image fom the console, and it confrms IOS relisience is not active
08-01-2013 08:19 AM
John,
There is a remote possibility that the IOS Resiliency (secure boot-image) has been activated in the past but the original configuration has been lost so the router does not "remember" the IOS Resiliency was activated.
Try entering these two commands in the global configuration while accessing the router via the console port (not remotely!):
secure boot-image ! may produce error messages - ignore them
Afterwards, check whether the IOS has been reinstated into the FLASH.
Best regards,
Peter
08-01-2013 08:56 AM
Hello
You can also post
Sh ver
Sh boot
Could be the iOS is in one or the flash directories
Res
Paul
08-01-2013 09:25 AM
Thank you Paul,
Sh boot command does not exist
I know the IOS exists somewhere because the router boots ok.
2811#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(11)XJ4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 13-Jul-07 22:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
2811 uptime is 2 hours, 52 minutes
System restarted at 09:28:49 PCLAIRE Thu Aug 1 2013
System image file is "flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 509952K/14336K bytes of memory.
Processor board ID FHK1302F0YV
3 FastEthernet interfaces
24 Serial interfaces
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
2811#
08-01-2013 09:32 AM
John,
Let's try some more brute force, shall we?
Please enter the following command, capture its entire output and post it here if possible. Thank you!
dir /all /recursive flash:/
Best regards,
Peter
08-01-2013 09:50 AM
2811#dir /all /recursive flash:/
Directory of flash:/*
Directory of flash:/bacdprompts/
4 -rw- 18836 Jan 31 2013 13:22:32 -05:00 app-b-acd-2.1.2.2-ReadMe.txt
5 -rw- 75650 Jan 31 2013 13:22:32 -05:00 en_bacd_allagentsbusy.au
6 -rw- 83291 Jan 31 2013 13:22:32 -05:00 en_bacd_disconnect.au
7 -rw- 63055 Jan 31 2013 13:22:34 -05:00 en_bacd_enter_dest.au
8 -rw- 37952 Jan 31 2013 13:22:34 -05:00 en_bacd_invalidoption.au
9 -rw- 496521 Jan 31 2013 13:22:38 -05:00 en_bacd_music_on_hold.au
10 -rw- 123446 Jan 31 2013 13:22:38 -05:00 en_bacd_options_menu.au
11 -rw- 42978 Jan 31 2013 13:22:40 -05:00 en_bacd_welcome.au
12 -rw- 34794 Jan 31 2013 13:22:40 -05:00 en_bacd_xferto_operator.au
Directory of flash:/CP7921G-1.0.3/
15 -rw- 871 Jan 31 2013 13:22:42 -05:00 CP7921G-1.0.3.LOADS
16 -rw- 1868518 Jan 31 2013 13:22:50 -05:00 APPS-1.0.3.SBN
17 -rw- 1461170 Jan 31 2013 13:22:56 -05:00 GUI-1.0.3.SBN
18 -rw- 2078210 Jan 31 2013 13:23:04 -05:00 SYS-1.0.3.SBN
19 -rw- 893001 Jan 31 2013 13:23:08 -05:00 TNUX-1.0.3.SBN
20 -rw- 2196478 Jan 31 2013 13:23:18 -05:00 TNUXR-1.0.3.SBN
21 -rw- 1300663 Jan 31 2013 13:23:24 -05:00 WLAN-1.0.3.SBN
Directory of flash:/Desktops/
Directory of flash:/Desktops/320x212x12/
24 -rw- 131470 Jan 31 2013 13:23:26 -05:00 CampusNight.png
25 -rw- 80565 Jan 31 2013 13:23:26 -05:00 CiscoFountain.png
26 -rw- 138278 Jan 31 2013 13:23:28 -05:00 Fountain.png
27 -rw- 109076 Jan 31 2013 13:23:30 -05:00 MorroRock.png
28 -rw- 108087 Jan 31 2013 13:23:30 -05:00 NantucketFlowers.png
29 -rw- 10820 Jan 31 2013 13:23:30 -05:00 TN-CampusNight.png
30 -rw- 9657 Jan 31 2013 13:23:32 -05:00 TN-CiscoFountain.png
31 -rw- 7953 Jan 31 2013 13:23:32 -05:00 TN-Fountain.png
32 -rw- 7274 Jan 31 2013 13:23:34 -05:00 TN-MorroRock.png
33 -rw- 9933 Jan 31 2013 13:23:34 -05:00 TN-NantucketFlowers.png
34 -rw- 628 Jan 31 2013 13:23:34 -05:00 List.xml
Directory of flash:/gui/
36 -rw- 4802 Jan 31 2013 13:23:36 -05:00 admin_user.html
37 -rw- 657587 Jan 31 2013 13:23:38 -05:00 admin_user.js
38 -rw- 1602 Jan 31 2013 13:23:40 -05:00 CiscoLogo.gif
39 -rw- 619 Jan 31 2013 13:23:40 -05:00 CME_GUI_README.TXT
40 -rw- 953 Jan 31 2013 13:23:40 -05:00 delete.gif
41 -rw- 16344 Jan 31 2013 13:23:42 -05:00 dom.js
42 -rw- 864 Jan 31 2013 13:23:42 -05:00 downarrow.gif
43 -rw- 6146 Jan 31 2013 13:23:42 -05:00 ephone_admin.html
44 -rw- 4658 Jan 31 2013 13:23:44 -05:00 logohome.gif
45 -rw- 3724 Jan 31 2013 13:23:44 -05:00 normal_user.html
46 -rw- 81443 Jan 31 2013 13:23:44 -05:00 normal_user.js
47 -rw- 1347 Jan 31 2013 13:23:46 -05:00 plus.gif
48 -rw- 843 Jan 31 2013 13:23:46 -05:00 sxiconad.gif
49 -rw- 174 Jan 31 2013 13:23:46 -05:00 tab.gif
50 -rw- 2433 Jan 31 2013 13:23:48 -05:00 telephony_service.html
51 -rw- 870 Jan 31 2013 13:23:48 -05:00 uparrow.gif
52 -rw- 3412 Jan 31 2013 13:23:48 -05:00 xml.template
53 -rw- 9968 Jan 31 2013 13:23:50 -05:00 xml-test.html
Directory of flash:/phone/
56 -rw- 2455771 Jan 31 2013 13:24:02 -05:00 apps31.8-2-2TR2.sbn
57 -rw- 49599 Jan 31 2013 13:24:04 -05:00 S00105000200.sbn
58 -rw- 2453315 Jan 31 2013 13:24:14 -05:00 apps70.8-2-2TR2.sbn
59 -rw- 339307 Jan 31 2013 13:24:16 -05:00 CP7905080002SCCP060817A.sbin
60 -rw- 1155568 Jan 31 2013 13:24:22 -05:00 cmterm_7920.4.0-03-02.bin
61 -rw- 1763446 Jan 31 2013 13:24:30 -05:00 cmterm_7936.3-3-13-0.bin
62 -rw- 14997798 Jan 31 2013 13:25:30 -05:00 cmterm_7985.4-1-2-0.bin
63 -rw- 331693 Jan 31 2013 13:25:32 -05:00 CP7902080002SCCP060817A.sbin
64 -rw- 129824 Jan 31 2013 13:25:34 -05:00 P00308000500.bin
65 -rw- 341088 Jan 31 2013 13:25:36 -05:00 CP7912080002SCCP060817A.sbin
66 -rw- 349794 Jan 31 2013 13:25:38 -05:00 P00405000700.bin
67 -rw- 439794 Jan 31 2013 13:25:40 -05:00 cnu31.8-2-2TR2.sbn
68 -rw- 2029545 Jan 31 2013 13:25:50 -05:00 P00503021500.bin
69 -rw- 2455771 Jan 31 2013 13:26:00 -05:00 apps11.8-2-2TR2.sbn
70 -rw- 439073 Jan 31 2013 13:26:02 -05:00 cnu11.8-2-2TR2.sbn
71 -rw- 2146975 Jan 31 2013 13:26:12 -05:00 cvm11sccp.8-2-2TR2.sbn
72 -rw- 302171 Jan 31 2013 13:26:14 -05:00 dsp11.8-2-2TR2.sbn
73 -rw- 377390 Jan 31 2013 13:26:16 -05:00 jar11sccp.8-2-2TR2.sbn
74 -rw- 662 Jan 31 2013 13:26:16 -05:00 SCCP11.8-2-2SR2S.loads
75 -rw- 662 Jan 31 2013 13:26:18 -05:00 term06.default.loads
76 -rw- 662 Jan 31 2013 13:26:18 -05:00 term11.default.loads
77 -rw- 2141829 Jan 31 2013 13:26:28 -05:00 cvm31sccp.8-2-2TR2.sbn
78 -rw- 302171 Jan 31 2013 13:26:30 -05:00 dsp31.8-2-2TR2.sbn
79 -rw- 376618 Jan 31 2013 13:26:32 -05:00 jar31sccp.8-2-2TR2.sbn
80 -rw- 643 Jan 31 2013 13:26:32 -05:00 SCCP31.8-2-2SR2S.loads
81 -rw- 643 Jan 31 2013 13:26:34 -05:00 term31.default.loads
82 -rw- 2453315 Jan 31 2013 13:26:44 -05:00 apps41.8-2-2TR2.sbn
83 -rw- 435144 Jan 31 2013 13:26:46 -05:00 cnu41.8-2-2TR2.sbn
84 -rw- 2141080 Jan 31 2013 13:26:56 -05:00 cvm41sccp.8-2-2TR2.sbn
85 -rw- 509329 Jan 31 2013 13:26:58 -05:00 dsp41.8-2-2TR2.sbn
86 -rw- 229333 Jan 31 2013 13:27:00 -05:00 jar41sccp.8-2-2TR2.sbn
87 -rw- 642 Jan 31 2013 13:27:02 -05:00 SCCP41.8-2-2SR2S.loads
88 -rw- 642 Jan 31 2013 13:27:02 -05:00 term41.default.loads
89 -rw- 642 Jan 31 2013 13:27:04 -05:00 term61.default.loads
90 -rw- 435605 Jan 31 2013 13:27:06 -05:00 cnu70.8-2-2TR2.sbn
91 -rw- 2143067 Jan 31 2013 13:27:16 -05:00 cvm70sccp.8-2-2TR2.sbn
92 -rw- 509329 Jan 31 2013 13:27:18 -05:00 dsp70.8-2-2TR2.sbn
93 -rw- 474957 Jan 31 2013 13:27:20 -05:00 jar70sccp.8-2-2TR2.sbn
94 -rw- 642 Jan 31 2013 13:27:22 -05:00 SCCP70.8-2-2SR2S.loads
95 -rw- 642 Jan 31 2013 13:27:22 -05:00 term70.default.loads
96 -rw- 642 Jan 31 2013 13:27:22 -05:00 term71.default.loads
97 -rw- 338891 Jan 31 2013 13:27:26 -05:00 CP7905080002SCCP060817A.zup
98 -rw- 458 Jan 31 2013 13:27:26 -05:00 P00308000500.loads
99 -rw- 705536 Jan 31 2013 13:27:30 -05:00 P00308000500.sb2
100 -rw- 130228 Jan 31 2013 13:27:30 -05:00 P00308000500.sbn
101 -rw- 350198 Jan 31 2013 13:27:34 -05:00 P00405000700.sbn
Directory of flash:/ringtones/
103 -rw- 8160 Jan 31 2013 13:27:34 -05:00 Analog1.raw
104 -rw- 8160 Jan 31 2013 13:27:36 -05:00 Analog2.raw
105 -rw- 5280 Jan 31 2013 13:27:36 -05:00 AreYouThere.raw
106 -rw- 5040 Jan 31 2013 13:27:36 -05:00 AreYouThereF.raw
107 -rw- 8160 Jan 31 2013 13:27:38 -05:00 Bass.raw
108 -rw- 12240 Jan 31 2013 13:27:38 -05:00 CallBack.raw
109 -rw- 16040 Jan 31 2013 13:27:38 -05:00 Chime.raw
110 -rw- 8160 Jan 31 2013 13:27:40 -05:00 Classic1.raw
111 -rw- 16080 Jan 31 2013 13:27:40 -05:00 Classic2.raw
112 -rw- 10800 Jan 31 2013 13:27:42 -05:00 ClockShop.raw
113 -rw- 2823 Jan 31 2013 13:27:42 -05:00 DistinctiveRingList.xml
114 -rw- 9600 Jan 31 2013 13:27:42 -05:00 Drums1.raw
115 -rw- 13440 Jan 31 2013 13:27:44 -05:00 Drums2.raw
116 -rw- 15840 Jan 31 2013 13:27:44 -05:00 FilmScore.raw
117 -rw- 16080 Jan 31 2013 13:27:46 -05:00 HarpSynth.raw
118 -rw- 8160 Jan 31 2013 13:27:46 -05:00 Jamaica.raw
119 -rw- 16080 Jan 31 2013 13:27:48 -05:00 KotoEffect.raw
120 -rw- 12720 Jan 31 2013 13:27:48 -05:00 MusicBox.raw
121 -rw- 8160 Jan 31 2013 13:27:48 -05:00 Piano1.raw
122 -rw- 15360 Jan 31 2013 13:27:50 -05:00 Piano2.raw
123 -rw- 9360 Jan 31 2013 13:27:50 -05:00 Pop.raw
124 -rw- 7200 Jan 31 2013 13:27:52 -05:00 Pulse1.raw
125 -rw- 4000 Jan 31 2013 13:27:52 -05:00 Ring1.raw
126 -rw- 4000 Jan 31 2013 13:27:52 -05:00 Ring2.raw
127 -rw- 4000 Jan 31 2013 13:27:54 -05:00 Ring3.raw
128 -rw- 4000 Jan 31 2013 13:27:54 -05:00 Ring4.raw
129 -rw- 4000 Jan 31 2013 13:27:56 -05:00 Ring5.raw
130 -rw- 4000 Jan 31 2013 13:27:56 -05:00 Ring6.raw
131 -rw- 4000 Jan 31 2013 13:27:56 -05:00 Ring7.raw
132 -rw- 495 Jan 31 2013 13:27:58 -05:00 RingList.xml
133 -rw- 10800 Jan 31 2013 13:27:58 -05:00 Sax1.raw
134 -rw- 14160 Jan 31 2013 13:28:00 -05:00 Sax2.raw
135 -rw- 16080 Jan 31 2013 13:28:00 -05:00 Vibe.raw
Directory of flash:/its/
137 -rw- 0 Aug 1 2013 09:29:26 -04:00 SEPDEFAULT.cnf
138 -rw- 1650 Aug 1 2013 09:29:36 -04:00 XMLDefault.cnf.xml
139 -rw- 311 Aug 1 2013 09:29:38 -04:00 ATADefault.cnf.xml
140 -rw- 824 Aug 1 2013 09:29:38 -04:00 XMLDefault7905.cnf.xml
141 -rw- 424 Aug 1 2013 09:29:38 -04:00 XMLDefault7902.cnf.xml
142 -rw- 824 Aug 1 2013 09:29:40 -04:00 XMLDefault7920.cnf.xml
143 -rw- 969 Aug 1 2013 09:29:40 -04:00 XMLDefault7921.cnf.xml
144 -rw- 404 Aug 1 2013 09:29:40 -04:00 XMLDefault7936.cnf.xml
145 -rw- 1043 Aug 1 2013 09:29:40 -04:00 XMLDefault7970.cnf.xml
146 -rw- 1147 Aug 1 2013 09:29:42 -04:00 XMLDefault7970-1.cnf.xml
147 -rw- 1220 Aug 1 2013 09:29:42 -04:00 XMLDefault7970-2.cnf.xml
148 -rw- 1043 Aug 1 2013 09:29:44 -04:00 XMLDefault7971.cnf.xml
149 -rw- 1147 Aug 1 2013 09:29:44 -04:00 XMLDefault7971-1.cnf.xml
150 -rw- 1220 Aug 1 2013 09:29:44 -04:00 XMLDefault7971-2.cnf.xml
151 -rw- 1065 Aug 1 2013 09:29:44 -04:00 XMLDefault7961.cnf.xml
152 -rw- 1169 Aug 1 2013 09:29:46 -04:00 XMLDefault7961-1.cnf.xml
153 -rw- 1242 Aug 1 2013 09:29:46 -04:00 XMLDefault7961-2.cnf.xml
154 -rw- 1043 Aug 1 2013 09:29:46 -04:00 XMLDefault7961GE.cnf.xml
155 -rw- 1147 Aug 1 2013 09:29:48 -04:00 XMLDefault7961GE-1.cnf.xml
156 -rw- 1220 Aug 1 2013 09:29:48 -04:00 XMLDefault7961GE-2.cnf.xml
157 -rw- 1043 Aug 1 2013 09:29:48 -04:00 XMLDefault7941.cnf.xml
158 -rw- 1043 Aug 1 2013 09:29:50 -04:00 XMLDefault7941GE.cnf.xml
159 -rw- 1043 Aug 1 2013 09:29:50 -04:00 XMLDefault7931.cnf.xml
160 -rw- 1043 Aug 1 2013 09:29:50 -04:00 XMLDefault7911.cnf.xml
161 -rw- 1043 Aug 1 2013 09:29:52 -04:00 XMLDefault7906.cnf.xml
162 -rw- 1043 Aug 1 2013 09:29:52 -04:00 XMLDefault7985.cnf.xml
163 -rw- 824 Aug 1 2013 09:29:52 -04:00 XMLDefault7912.cnf.xml
164 -rw- 510 Aug 1 2013 09:29:52 -04:00 XMLDefault7910.cnf.xml
165 -rw- 404 Aug 1 2013 09:29:54 -04:00 XMLDefault7935.cnf.xml
166 -rw- 919 Aug 1 2013 09:29:54 -04:00 XMLDefault7960.cnf.xml
167 -rw- 1023 Aug 1 2013 09:29:54 -04:00 XMLDefault-1.cnf.xml
168 -rw- 1096 Aug 1 2013 09:29:56 -04:00 XMLDefault-2.cnf.xml
169 -rw- 1007 Aug 1 2013 09:29:56 -04:00 XMLDefaultCIPC.cnf.xml
176 -rw- 903 Aug 1 2013 09:30:00 -04:00 united_states_7960-tones.xml
177 -rw- 8777 Aug 1 2013 09:30:00 -04:00 united_states_7960-font.xml
178 -rw- 1313 Aug 1 2013 09:30:02 -04:00 united_states_7960-kate.xml
179 -rw- 19750 Aug 1 2013 09:30:02 -04:00 united_states_7960-dictionary.xml
180 -rw- 2711 Aug 1 2013 09:30:02 -04:00 united_states_SCCP-dictionary.xml
170 -rw- 221560 Jul 29 2013 14:10:10 -04:00 crashinfo_20130729-181010
171 -rw- 176780 Jul 29 2013 14:17:12 -04:00 crashinfo_20130729-181713
172 -rw- 182636 Jul 30 2013 09:09:54 -04:00 crashinfo_20130730-130955
2811#
It is weird, because on July 27th, the IOS was there, I kept an old print-out:
2811#
2811#sh flash
-#- --length-- -----date/time------ path
1 45182188 Jan 31 2013 13:16:50 -05:00 c2800nm-adventerprisek9-mz.124-11.XJ4.bin
2811#
2811#sh flash
08-01-2013 09:56 AM
John,
I am scratching my head. Hmmm... Would you mind running fsck flash: command and see if any errors are reported or corrected?
Best regards,
Peter
08-01-2013 11:24 AM
2811#fsck flash:
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
fsck of flash: complete
2811#
Nothing....
there must be a way to "repair" thatt flash.... In fact, the reason I need to see it is because I want to delete it to upgrade to a newer version that allows Network Object Groups...(c2800nm-adventerprisek9-mz.124-20.YA2.bin does).
But if it can't see it, it can't delete it.
Where can I see the boot image it uses upon booting ? Can I do a display of
boot system flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin ?????
To see under what flash directory it is located ? I know it's there, somewhere.....
08-01-2013 11:36 AM
John,
I wonder - do you have a CF card reader somewhere around? With any luck, the CF card is formatted with FAT filesystem so it should be plain simple to check its contents under Windows or Linux.
Best regards,
Peter
08-01-2013 03:29 PM
Yes, verified with a compact flash reader, all the files are there as per the dir flash:, but no IOS.
The IOS must be there because when I add the 59 MB on the compact flash card + the 23 MB left on it, I am missing 45MB to total the 128MB capacity....
45 MB is the size of the IOS....
08-01-2013 12:30 PM
how about
show bootvar
res
paul
Sent from Cisco Technical Support Android App
08-01-2013 03:31 PM
That command does not exist on my router.
I got nothing that start by show b in privilege mode 15
