Webcast-Catalyst9k
IOS not supported to HWIC-2ce1 pri card
        I have 3845 router using IOS flash:c3845-advsecurityk9-mz.124-3c.bin .  after that we have install HWIC-2E1-PRI and change the ios to
1) c3845-advsecurityk9-mz.124-20.T5
2) c3845-advsecurityk9-mz.124-24.T3
But the ios not supported to hwic card , card is ok . so pls suggest the sepcific IOS to 3845 router Support hwic card.
Re: IOS not supported to HWIC-2ce1 pri card
Hi Mayank,
The card should be supported from 12.4(20)T upwards.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88.html
How do you know the card is not faulty? Have you tried in in a different HWIC slot and/or router?
Kevin
Hi Mayank,
Please go to cisco website and find the tool "Direct Configuration Tool", the enter the your product name and try to configure your product with new IOS image.
I am sure, there is an issue with feature set on IOS, so select the different feature set IOS and let the minimum release 12.(4)T
Hope this resolves your issue.
Shahid Ansari
460
