Community Member
IOS requirment for BGP
Is there any IOS requirmrnt fo rset up BGP.(eg.IP PLUS)
Re: IOS requirment for BGP
In earlier IOS versions, BGP was supported starting from the SP feature set (not in IP Base and IP Voice).
Begining from 12.4(4)T, BGP is supported with advance security feature set.
Begining from 12.4(11)T, BGP is supported with even IP base and IP voice feature set.
BR,
Mohammed Mahmoud.
Community Member
Thanks for the quick respond and appreciate.
Which means built in IOS comes in routers these days are capable of configuring BGP ?
If it is 12.4(11)T or higher then the answer is yes, other wise please use Cisco feature navigator:
http://www.cisco.com/go/fn
BR,
Mohammed Mahmoud.
Community Member
Thanks a lot for the advice
You are very welcomed.
115
