08-24-2009 12:23 AM - edited 03-04-2019 05:49 AM
I just upgraded a Cisco 871 VPN router ios from c870-advipservicesk9-mz.124-24.T.bin TO the newer version >>c870-advipservicesk9-mz.124-24.T1.bin. Upon completion, I reloaded the router only to get the msg -
Booting flash:/c870-advipservicesk9-mz.124-24.T1.bin
ELF Loader: read error
Elf loader error
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 3-148) platform with 131072 Kbytes of main memory
Elf loader error
And the router defaults to rommon mode.
I'd appreciate assistance getting it out of rommon and loading the older ios I removed. I will need to remove the new one I just loaded to make space on flash for the old one to be reloaded. I am at customer site right now, and need to bring this up ASAP. ouch.Thanks for any help.
08-24-2009 02:15 AM
When in rommon, you can use tftpboot to load and boot with an IOS from a tftp seerver, like tftpd323.
08-24-2009 04:29 AM
Paolo, thanks for the response, but I used tftpdnld, the file began loading but flash memory was insufficient to accomodate the old IOS. So I tried to delete the corrupted IOS on flash to create more space. when I tried this, I got a "permission denied" error msg. How can I force it to delete the corrupted IOS and? Pls see error msg
rommon 23 > delete c870-advipservicesk9-mz.124-24.T1
Are you sure you want to delete "c870-advipservicesk9-mz.124-24.T1" (y/n)?y
File "c870-advipservicesk9-mz.124-24.T1" not deleted -- permission denied
08-24-2009 06:02 AM
Try using the full path description:
delete flash:c870-advipservicesk9-mz.124-24.T1
Also, if there is a "format" or "erase" command in the ROMMON mode, you may want to try that one to completely erase your entire FLASH. If its contents are corrupted, then this might be necessary.
Best regards,
Peter
08-24-2009 06:58 AM
I tried deleting the Dir. instead of the file and got the same response.
rommon 26 > delete c870-advipservicesk9-mz.124-24.T1
rommon 27 >
There is a >rmdire command under rommon, but at this point I am not sure if I should even consider using it.
08-24-2009 07:52 AM
You cannot delete a non-empty directory and you cannot delete the root directory.
Have tried using the format/erase command in the ROMMON?
Best regards,
Peter
08-24-2009 09:44 AM
Erase is not an available option in rommon on the 871.
Fromat is available and rmdir is available, but I have no experience with their use in this mode, any help?
08-24-2009 11:59 AM
The format command in the ROMMON performs a format operation on the FLASH. It effectively erases the entire FLASH including its contents.
The command is easy to use - simply write format flash:. After it finishes, you will need to download the proper IOS using the tftpdnld back to the FLASH.
Note that as every format operation, this command erases the entire FLASH with all files currently stored there.
Best regards,
Peter
08-24-2009 12:08 PM
Thanks Peter, I was able to get TAC and worked with them to fix. But weird thing though, my config remained on the router and became the default when I tftpdnld'd the replacement IOS. I no longer see the config.text file, but that's okey, it works.
But my question, what could be the reason for the error below----
Elf loader error
I cannot find any description/explanation for this IOS reload error. Thanks again
08-24-2009 12:24 PM
Can be a corrupted image.
08-24-2009 12:36 PM
I can only speculate here... The ELF is an acronym of the Executable and Linking Format and it describes a format of binary executable files. It is very popular in Unix-type operating systems and also it appears that the IOS images are basically compressed ELF binaries bundled with a decompression and startup routine.
The 'mz' images require that a decompression routine first decompresses the binary into RAM of the router and then proceeds to execute it. Apparently, the messages you see here are related to the fact that the decompression routine is not either able to find the image or it is having trouble decompressing and/or executing the unpacked IOS image.
I have noticed that on some Cisco platforms, the bootloader does not accept the first slash sign right after the colon. If the message still appears, try to enter the following command in the global configuration mode:
boot system flash c870-advipservicesk9-mz.124-24.T1.bin
and save the configuration. Then try to reload the router.
Best regards,
Peter
08-24-2009 01:06 PM
Thank you all for your contributions. I was able to format flash: and tftpdnld the previous IOS.
08-24-2009 01:15 PM
Very good, please remember to rate useful posts with the scrollbox below.
