IOS upgrade for 6500 Supervisor 2
Any body can help me with this?
I haven't experience in this
Re: IOS upgrade for 6500 Supervisor 2
Do u mean upgrade from CatOS to native IOS?
If Yes here you go.
Read it carefuly before start on.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
Best Regards,
Mounir Mohamed
No, we already have IOS.
But I'm afraid to upgrade it, 'cause of that mess with Switch and Route Processors, MSFS, and so on
Well, you are in better situation than what i was suggest, moving from CatOS to IOS is painful than upgrading from IOS to another IOS image or feature set,
Check this out:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801347e2.shtml
Best Regards,
Mounir Mohamed
Hi AAshih,
If you have 2 sups in your chassis an you want to upgrade the 2 at a same time please find this link
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807714cb.shtml#upgrade
If you just jave one sup running IOS image on your box please use this link
http://www.cisco.com/warp/public/473/161.html#maintask2
Please read the links carefully before you start upgrade and incase you are stuck somewhere please come back with your doubts before you start upgrade.
Ankur
*Pls rate all helpfull post
Thank you
154
