07-22-2006 02:33 PM - edited 03-03-2019 01:25 PM
Hi All,
I have a cisco 1720 and I just upgraded its IOS to 12.2(37)
When I do a "sh ver", in the top of the output it shows the new version, but somewhere in the bottom, it shows
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
I would love to know if I messed up in the upgrade, or if this System Bootstrap version has to do with something else and it's something I shouldn't worry?
please help
Solved! Go to Solution.
07-22-2006 02:37 PM
You should not worry indeed. The bootstrap is something else.
Hope this helps,
07-22-2006 02:37 PM
Hope this helps,
07-22-2006 02:51 PM
great, this is the assurance I needed from any of you big cats.
now, what command will it show me what features this router has? I thought "sh run" will do, but I don;t see anything. I'd like to know if it has the encryptions I was looking for, VPNs, firewall, etc
thanks
07-22-2006 03:07 PM
The best way of finding that out is to use the Cisco Feature Navigator at www.cisco.com/go/fn, and do a search for the features within the particular image you are using.
Paresh
07-22-2006 03:20 PM
That's exactly what I did before I downloaded this image. It said it had all those features... so I just wanted to make sure that they were indeed there by typing a command...
In the past, I have ran into problems where I needed to enable or make use of a feature, for example the Firewall set on the routers, and I called cisco and they never said "upgrade to a newer IOS", they said I needed an activation key or something like that
please advise
07-22-2006 03:41 PM
I'm not aware of any features out there that need an activation key. You pay for features by buying the appropriate feature set which you have done already. So the bottom line is that if you have got a feature set that supports a particular feature, you should be able to configure it.
Paresh
