Community Member
IOS
hi..
anybody you there knows all about the router command or IOS can you give where a good site for those command
Re: IOS
your question is very broad.
here ya go
http://www.cisco.com/en/US/tech/tk648/tsd_technology_support_category_home.html
Please rate all helpful posts
Rgds
Jorge
Re: IOS
Re: IOS
HI Paul,
Please refer link below:
http://www.cisco.com/univercd/home/home.htm
Based on the Version / Models you choose (in the drop-down box) the required Documentation will be listed. You can choose as per your requirement.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Community Member
Re: IOS
Hi Paul,
Given below is a link that provides release notes and command reference for all cisco devices.
For router IOS selection try the tool given below:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hope this helps!
104
