Bronze
ip cef on ASR vs ISR G2
On an ISR G2 platform I can simply enter ip cef and be done.
On the ASR100o platfrom there is no default and must determine which of these below is appropriate.
Which would be the "equivalent" of what is being done on an ISR G2 platform?
router(config)#ip cef ?
  accounting          Enable CEF accounting
  distributed         Distributed Cisco Express Forwarding
  load-sharing        Load sharing
  optimize            Optimizations
  traffic-statistics  Enable collection of traffic statistics
Everyone's tags (1)
1 ACCEPTED SOLUTION
Icaruso,
The ASR I'm sure has a hell of a lot more capabilities than the ISR G2 series.
ip cef distributed - This can offload your CEF onto a separate SPA card
ip cef load-sharing - Allows you to change load-balancing option suchas per packet load balancing etc etc.
ip cef accounting - Allows accounting services to be used for CEF
The other two I honestly don't know.
I hope that helped a little bit.
Icaruso,
Bronze
Hi John,
distributed is the way to go.
Thanks.
509
