Community Member
IP Default-gateway
How get configured IP default gateway on router
Hall of Fame Super Blue
Re: IP Default-gateway
You would simply use this commmand from global config mode
router(config)# ip default-gateway
Note that you would only do this on a router if you have ip routing disabled. If your router is acting as a router then you need to look into the ip default-network command or the ip route 0.0.0.0 command. See this link for more details
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094374.shtml
Jon
Community Member
Hi Jon,
thanks for your response. I already configured ip default gateway on interface, but want to see on to router thru show command. Thanks.
Hall of Fame Super Silver
use
ip route 0.0.0.0 0.0.0.0 x.x.x.x
where x.x.x.x is the ip address of the IP next-hop default gateway
this requires that ipv4 routing is turned on with
ip routing
if ip routing is disabled like in a L2 switch
ip default-gateway x.x.x.x
Hope to help
Giuseppe
Hi Anand,
Yes, You can check IP default-gatway on the L3 Switch/Router by using the following command.
#Show ip route 0.0.0.0
hope this helps !!!
Shaheen
261
