Webcast-Catalyst9k
ip helper-address
Can I forward only DHCP broadcast to server 1 and only TFTP broadcast to server 2?
Client
Router --- Server1
Server2
I know that by default
ip helper-address X.X.X.X
forwards 8 protocols and I can get the rid of them using the
no ip forward-protocol udp 37
no ip forward-protocol udp 49
But in case of multiple helper-address, how to enable only one protocol per destination IP?
Thanks to read!
Re: ip helper-address
hello,
i think by using two helper address command with appropriate server addresses and by allowing appropriate udp port number you can achive it.
rate this post if it helps
regards
Devang
If I use 2 ip helper-address and I leave enabled 2 protocol to be forwarded, both bradcast will be forwarded to both destinations.
I haven't tried yet, but can an access-list in output sort this out?
Hall of Fame Super Gold
Stefano
I do not believe that there is any way to send only one type of message to one server and a different type of message to another server. I do not believe that an access list will do that either - but you are welcome to test it and let us know the outcome.
You can use ip forward-protocol/no ip forward-protocol to control what kind of messages get forwarded by ip helper-address. But whatever set of messages are enabled are sent to each server.
Rick
Gold
I don't think you will be able to filter messages that are produced by the router itself with a access list.
A method that should work is to use
IP LOCAL POLICY ROUTE-MAP xxxx
Route-map xxxx
Match IP address test
set interface null 0
ip aceess-list extended test
Permit udp any host x.x.x.x eq 37
permit udp any host x,x,x,y eq 49
Deny ip any any
In this case what you permit is dropped.
For those of you who have not used the local policy routing make sure you try it on a lab router first you can easily lock yourself out of the router.
hi
here you are matching the traffic for the perticular server and then by accesslist you are selecting the traffic of UDP port and then you divert that trafice to NULL 0 by using route maps
am i right?
regards
Devang
119
