IP NAT Pool question
Hi Experts,
I have one issue here.. There are 2 routers and they are running HSRP on the fast-Ethernet.
THe NAT config is "ip nat pool CISCO x.x.x.x y.y.y.y netmask 255.255.255.0.
ip nat inside source list 21 pool CISCO
access-list 21 permit z.z.z.z
The current NAT always happens at Router 1, meaning when i shown ip nat translations, the entry is there.
Now, when Router 1's HSRP is down, the traffic went to Router 2, but the NAT doesn't get translated there although the commands are the same.
What gone wrong actually?
cindy
Re: IP NAT Pool question
Could you share config. of R1 and R2 with altered sensitive info.?
Cindy,
When HSRP state changes, NAT translations will not switch over and all the dynamic NAT entries have to reestablished from the 2nd router. The redundancy is achieved only for static NAT entires which exist in both the routers
Stateful NAT enables continuous service for dynamically mapped NAT sessions.
SNAT can be configured to operate with HSRP to provide redundancy and the active and standby state changes are managed by HSRP
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_white_paper09186a0080118b04.shtml
http://www.cisco.com/en/US/docs/ios/12_4/12_4_mainline/snatsca.html
Narayan
Narayan,
Thanks for your helpful comments.
But if the commands for IP NAT pool also configured at both routers, just curious why the NAT cannot be build again on Router 2 when Router 1 failed on the HSRP?
Yes it will.. but the NAT translations have to be reestablished on the second router
Routers do not synchronise the NAT translation entries via HSRP
Narayan
What I understood from Cindy's original post was that there's a problem of re-establishment of NAT translations in R2.
Is that it?
Yeah..
Actually i am curious why the NAT translation cannot work at Router 2. although the command is there..
but i am getting closer to the answer with Narayan and you guys's reply..:)
One thing is, static NAT no prob on Router 2 rite?
is it only applied to Dynamic NAT?
and how can i establish the NAT if i dun want to use SNAT?
thanks.
Blue
Cindy:
Be clearer.
Is the problem with re-estabishing NAT translations after failover to the secondary or is it that the original NAT translations from the primary are not carried over to the secondary?
VL
VL,
Yup, is the problem with re-establishing NAT translations after failover to the secondary router as the secondary router also consist of IP nat pool command which is similar to Primary router..
Thanks again.
Blue
Ok, so what you're saying is that the NAT translations are not being restablished from scratch on the secondary router.
OK, you don't need SNAT for that. Thats just normal NATing.
Perhaps you should post your configs and lets see what you have going on.
VL
Yes Cindy, let's have a look at your configurations.
Blue
Narayan:
great explanation!
I like the way you differentiated between static and dynamic NAT. Thats a point a lot of people [used to] miss, including myself.
Victor
VL,
So,i need to knwo how to re-establish the NAT translation at Router 2 if Router 1 HSRP fails.
Thanks again.
Blue
VL
Thanks VL.
I will get back to you soon. It is dynamic NAT config that runs on both router.
Will get back on the config once ready.
Hall of Fame Super Silver
Cindy
I do not want to just pile on here. But if we are to give you effective help we really need to see the config (eapecially all the NAT and the interfaces) from both of the routers. You have said a couple of times that the NAT on the second router is similar to the first. We need to see specifically what is the same and what is different.
Rick
201
