IP Nbar
Please any one can help me . This following IOS is support Ip Nbar protocol or not
c1700-k9o3sy7-mz.123-1a.bin
Re: IP Nbar
You can use the below tool to find out the same..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
Re: IP Nbar
I have enabled the IP nbar protocol discovery on interface. user are able to access all the internet application but when seeing the sh ip nbar prptocol discover it showing blank.
Re: IP Nbar
once you had enabled NBAR on the internet interface you need to use the following command:
"show ip nbar protocol-discovery stats bit-rate top-n 10"
You should see the top 10 protocols and http should be at the top.
ps: also make sure ip cef is enabled.
Router(config)#ip cef
Rate if this helps.
Thanks.
Z
Re: IP Nbar
Hi thanks for your help,
I have enabled ip cef also but still I am getting same zero table while checking the nbar
125
