Community Member
IP phone registration problem
I have a head office and couple of branch offices, Head office IP phones are connected with call manager correctly. head office i have 4500 series switch, in the switch phones are connected with vlan 112, callmanager connected with vlan 100. In the call manager connected switch port is configured as following;
interface GigabitEthernet3/21
description CCM
switchport access vlan 100
switchport mode access
switchport voice vlan 112
service-policy output autoqos-voip-policy
qos trust device cisco-phone
qos trust cos
auto qos voip cisco-phone
tx-queue 3
   priority high
   shape percent 33
spanning-tree portfast
out side interface connected with pix firewall and configured with vlan 500
interface GigabitEthernet3/24
description FIREWALL
switchport access vlan 500
load-interval 30
problem is none of the branch office phones registered with call manager even though IP connectivity is still there. branch offices do not have any vlan configurations
please any help on this
thanks
theva
Hall of Fame Super Gold
Re: IP phone registration problem
Theva
Having switchport voice vlan 112  configured on ports where there may be phones connected makes good sense. But I do not see why you have it configured on the port that connects to the firewall.
My first guess at the problem focuses on your statement that the remote does not have any VLANs configured. So please explain to us how the phones are connected at the remote and what is configured to send the phone traffic from the remote to the head office.
My second guess is that the firewall may not be permitting the traffic from the remote sites to the Call Manager. Can you verify that there are access rules on the firewall that permit the phone traffic to Call Manager?
Rick
Community Member
Hi Rick,
Thanks a lot for your prompt response,
In the remote sites phones are connected with the switch (POE) with out any specific configuration, and getting the IP via DHCP configured on the router next to the Switch.
In the firewall IP traffic open, what else has to open?
regards,
Theva
Purple
It would be great seeing the firewall rules, can you post them?
Cisco phones are using SCCP( TCP port 2000 by default ) to communicate with CallManager.
Regards.
Community Member
dear cadetalin,
following is my firewall inbound rule regarding the TFTP and call manager
access-list inbound permit udp any host 10.12.3.24 eq 2000
access-list inbound permit tcp any host 10.12.3.24 eq 2000
access-list inbound permit tcp any host 10.12.3.24 eq 3389
access-list inbound permit udp any host 10.12.3.24 eq tftp
regards,
Theva
Purple
hi,
In your ACL the tftp keyword will match port 69 which is control port for tftp but afterwards the tftp daemon will choose a random udp port for data transfer and here the traffic from your cisco phones to this port will be blocked by your ACL.
I would modify this ACL like this:
access-list inbound extended
line 50 permit udp "ip-phones subnet" "wildcard mask" host 10.12.3.24 ge 1024
regards.
Community Member
Hi Cadetalain,
I amend my access list as you said and also permit all the ip traffic with out any restriction. but when I checked the hit count, none of the traffic match the UDP traffic
access-list inbound line 9 permit udp 172.16.96.0 255.255.224.0 host 10.12.3.24 gt 1024 (hitcnt=0)
access-list inbound line 11 permit ip any any (hitcnt=167)
regards,
Theva
Community Member
further more to access-list and firewall i would also like to mention here that 99% phones are not registering at all. but some time only one or two phones registered properly and later they also unstable.
regards,
Theva
Purple
what is the hit count for the line with tftp?
Community Member
I actually removed all the accesslist and have only permit ip any any statement
Theva
Purple
which is the same as no ACL anyway and so has it helped doing so?
Regards.
Community Member
No, Problem did not solve yet
Don't you think problem  on the VLANs?
Theva
Purple
At which stage of boot process are your phones stuck? Are they getting an IP with DHCP? maybe you can try on some phones to do config on the phone directly and put the correct VLAN and a static IP along with the address of TFTP server and UCM server.
Regards.
Community Member
phones are stucks in the "opening ip"stage. i have tried with static phone configuration but things are remaining as same.
Theva
Purple
Can you post config of branch office switches and routers please.
Regards.
491
