12-05-2008 09:34 AM - edited 03-04-2019 12:36 AM
Dear Net-pro!
plz i want a powerfull links that help me to design/implement/configure an ip telephony for a small company[55 ip phone]
2)what's the reasons for rib fialure in BGP Table and how can i start The troubleshooting issues
thanks
12-05-2008 09:50 AM
hi alsayed,
First of all, You need to run across this link.
http://www.cisco.com/en/US/netsol/ns818/networking_solutions_program_home.html
IMHO, You can use CCME to accomplish this requirement. If you have a plan to increase more ip phones then you should deploy CCM in your network. CCME is enough in your case. You have to purchase ISR Router that supports CCME to do so.
RIB failure is telling you that the router has already installed the same route with a better administrative distance in the routing table. Let's check by using "show ip route".
Toshi
12-07-2008 08:54 AM
