01-31-2014 05:33 PM - edited 03-04-2019 10:13 PM
Our IP WAN uses Telstras IPWAN MPLS network, We have a server that we set the DSCP markings to AF31( precedence flash)
now all the packets leaving the head end are correctly marked, but when they arrive at the branch about 25% of the packets have lost their markings and is set back to 0. Now telstra have checked their network and see the packets correctly marked. This only leaves their Switch on site and our 3945 router
Now the question is: is there anyway input packets on a3945 Gigabit interface can change the markings on packets?
Note only one site exhibits this problem out of 15 with 3945 routers and same config.
see relevent config below
Head office IPWAN config.
interface GigabitEthernet0/2
bandwidth 80000
ip address 172.28.4.254 255.255.255.252
ip access-group 190 out
ip wccp 62 redirect in
ip flow ingress
ip flow egress
tx-ring-limit 64
tx-queue-limit 64
duplex auto
speed auto
service-policy output QOS_OUT_NEW
Branch IPWAN config
description FNN N3819428R IPWAN
bandwidth 4000
ip address 172.28.29.254 255.255.255.252
glenelgip access-group 190 in
ip flow monitor Monitor-FNF input
ip flow monitor Monitor-FNF output
tx-ring-limit 64
tx-queue-limit 64
duplex full
speed 100
service-policy output 4Mbps
Access-list 190 at head office
sh access-l 190
Extended IP access list 190
10 permit ip host 172.16.94.5 any precedence routine
20 permit ip host 172.16.94.5 any precedence priority
30 permit ip host 172.16.94.5 any precedence immediate
40 permit ip host 172.16.94.5 any precedence flash (5764 matches)
50 permit ip host 172.16.94.5 any precedence flash-override
60 permit ip host 172.16.94.5 any precedence critical
70 permit ip host 172.16.94.5 any precedence internet
80 permit ip host 172.16.94.5 any precedence network
90 permit ip host 172.16.94.5 any
100 permit ip any any (1055808 matches)
Access-list 190 at branch
10 permit ip host 172.16.94.5 any precedence routine (1888 matches)
40 permit ip host 172.16.94.5 any precedence flash (3852 matches)
100 permit ip any any (80444 matches)
01-31-2014 11:25 PM
Can you show us the policy-maps as well?
What did the service provider say? How did they test it? Is it possible you are filling up your quota and some packets get remarked due to policer at SP?
Daniel Dib
CCIE #37149
Please rate helpful posts.
