05-16-2007 05:22 AM - edited 03-03-2019 05:00 PM
Are IP blocks assigned to ISP's with any kind of logic? More specifically, if I looked at 209.x.x.x could I tell which State or Geographical area that block belongs to?
05-16-2007 05:27 AM
You can use the WHOIS from the regional NIC to find the ISP
You can also use the IP Address Geographic Locator http://www.geobytes.com/IpLocator.htm
Dandy
05-16-2007 05:50 AM
hi,
The Internet Assigned Numbers Authority (IANA) delegates Internet resources to the RIRs, and in turn, the RIRs follow their regional policies for further sub-delegation of resources to their customers, which include Internet service providers and end-user organizations.
Please check the attached diagram.
And as Dandy said, you can use WHOIS for each RIR to know the owner of the IPs.
You can also use this website, i find it useful:
http://www.fixedorbit.com/search.htm
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
05-16-2007 06:00 AM
Thanks. looking at the geobytes link leads me to believe that somewhere out there, there is a repository for all of this information. I'm just trying to see if there is a directory that can be seen in it's entirerty
