ip routing command not working when all fastethernet are shut
vvinod123
I have a 2811 router. Two WAN interfaces are UP in that router. When I check in "sh ip route" output, then I get the below mentioned output.
Router#sh ip route
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
Router#
There is a default route configured already using ip route 0.0.0.0 0.0.0.0 command. But when I checked the configuration, I could see an entry "no ip routing". Kindly note that all my other interfaces including fast ethernet are administratively shutdown.
Now I enter the configuration mode & give "ip routing" command. The moment I gave this command, I lost the connectivity. (I have telneted to this router via one of the WAN interfaces).
But this is not happening when one of the fast ethernet interface is UP. I mean, I give "no shut" to one of the fast ethernet & then try "ip routing". Now I can see routes in "sh ip route" command.
Is this some kind of bug, or is there a logic like for a router to enable routing, atleast one of the ethernet interface should be UP.
9 Replies 9
jolmo
Level 4
Level 4
Can you post running-config of this router?
vinod
In general there is not any requirement that you must have at least one Ethernet interface up to enable ip routing. I agree with Jose that there must be something in the router config that is causing this behavior and if you post the router config we may be able to identify what it is. I wonder about the default route and how it is configured and whether this may be causing it. Or I have seen situations where a router had both a default route and a default-gateway configured. With "no ip routing" the default gateway would be used and with "ip routing" the default gateway would not be used and the default route would be used. Perhaps this is the situation in your configuration?
So please post the router config so that we may be able to help you to resolve this.
Rick
Rick
Hi.. the router config is as below:
Router#sh run
Building configuration...
Current configuration : 2233 bytes
version 12.4
hostname
boot-start-marker
boot-end-marker
enable secret 5 $1$nUdH$/SfrWV4ybAzAUAHlCAQoF.
enable password
no aaa new-model
resource policy
ip subnet-zero
no ip routing
no ip cef
interface FastEthernet0/0
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
no ip route-cache
shutdown
isdn point-to-point-setup
interface BRI0/1/0
no ip address
no ip route-cache
shutdown
interface Serial0/2/0
description "To Cloud"
ip address 12.1.32.45 255.255.255.252
encapsulation ppp
no ip route-cache
interface Serial0/2/1
bandwidth 1984
no ip address
encapsulation ppp
no ip route-cache
clock rate 2000000
interface Serial1/0
description "Main"
ip address 10.10.56.89 255.255.255.252
no ip route-cache
interface Serial1/1
no ip address
no ip route-cache
shutdown
no dce-terminal-timing-enable
interface Serial1/2
no ip address
no ip route-cache
shutdown
interface Serial1/3
no ip address
no ip route-cache
shutdown
interface Serial1/4
no ip address
no ip route-cache
shutdown
interface Serial1/5
no ip address
no ip route-cache
shutdown
interface Serial1/6
no ip address
no ip route-cache
shutdown
interface Serial1/7
no ip address
no ip route-cache
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 12.1.32.46
ip route 10.10.1.0 255.255.255.0 12.1.32.46
ip route 10.10.59.128 255.255.255.192 10.10.56.90
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password
login
scheduler allocate 20000 1000
end
Router#
vvinod.
Hi Vinod ,
enable ip routing on the router as it is disbled on the router currently.
satish
aravindhs
Your running config shows 'no ip routing' on it still. Is it your problem that it stays even after you do 'ip routing' ?
cheers
vinod
Thanks for posting the router config. Unfortunately I am still puzzled about your problem. The default route appears to be correctly configured and points out the first serial interface. When configured with "no ip routing" the router is acting as an IP host and will not use the default route. With ip routing enabled the router does use the default route.
When you were telnetted into the router what was the IP address that you were using? I wonder if your telnet was coming in on the second serial interface and when you enabled ip routing if the default route was sending the response packets out the first serial interface?
Rick
Rick
Hi Rick
I was telneting to the IP: 12.1.32.45. Which is in the default route.
But I could not understand the point what difference it makes that the "ip routing" command works fine when i give "no shut" to my fa0/1?
vvinod.
vvinod
I also do not understand why no shut on fa0/1 would make a difference about ip routing. Can you post the output of show interface fa0/1, and of show ip interface fa0/1?
If you were telnetting to 12.1.32.45, were you on the 12.1.32.46 device?
Rick
Rick
Hi Rick
I think this is some kind of a bug. Will try with a different router & revert back. the show interface outputs are as pasted below. Thanks for your support.
Router#sh int FastEthernet0/1
FastEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0019.06db.b211 (bia 0019.06db.b211)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:09, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6000 bits/sec, 10 packets/sec
246386 packets input, 24105370 bytes
Received 246386 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
7587 packets output, 783647 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
Router#sh ip int FastEthernet0/1
Internet protocol processing disabled
Router#
vvinod.
