ip routing protocol purge interface command not taking
ip routing protocol purge interface command is not taking on cisco 3845 router, but I am able to put the command on 7204vxr
Pls suggest any H/w dependency / IOS bug / IOS dependency is present on 3845 router for enabling the command
9 Replies 9
Peter Paluch
Subhojit,
The support for this command is generally present only on service provider-grade routers and IOSes. If your 3845 does not support this command then the feature is simply not present in that IOS. However, do not worry too much about this. You would need to have a large routing table on your 3845 to see any benefit from using this command. The functionality of your router is not impaired in any way.
Best regards,
Peter
Thanks for you details
However can u pls confirm whether I need to upgrade the IOS
present IOS : c3845-advipservicesk9-mz.124-15.T16.bin
Hello Subhojit,
If you are not experiencing any issues and the router works in a stable and efficient manner for you then I see no reason to upgrade your IOS. I have checked your IOS version - while there are updates, this version has not been marked as having any grave problem, and so if you are not experiencing any issues yourself, then I see no reason to upgrade. With routers, the general rule is: "If it isn't broken, don't fix it".
Best regards,
Peter
We are enaling MPLS on this router in out Internal MPLS Cloud & same commands needs to be updated for faster propagation of the route.
So, I am just looking for the info
Hello Subhojit,
How many entries in the routing table does the 3845 have? Would you mind posting the show ip route summary output command please?
Best regards,
Peter
P routing table name is Default-IP-Routing-Table(0)
IP routing table maximum-paths is 16
Route Source    Networks    Subnets     Overhead    Memory (bytes)
connected       0           4           324         512
static          0           0           0           0
ospf 64907      0           239         20448       30592
  Intra-area: 239 Inter-area: 0 External-1: 0 External-2: 0
  NSSA External-1: 0 NSSA External-2: 0
bgp 64907       0           0           0           0
  External: 0 Internal: 0 Local: 0
internal        2                                   2296
Total           2           243         20772       33400
Removing Queue Size 0
static          0           0           0           0
bgp 64907       0           0           0           0
internal        2                                   2296
Hi Subhojit,
You have around 243 entries in your routing table. Even if your router supported the ip routing protocol purge interface command, the speedup would be negligible (in orders of milliseconds, tens of milliseconds perhaps). I see no reason to worry about this.
Best regards,
Peter
hi,
Thanks for your continous guidance. i know performace will not be improved on greater level
But, as per our organization current standard for MPLS, I need to enable the command
Can you pls guide/help me with the IOS version what I need to upgrade for enabling the feature
Many Thanks,
Subhojit
Hello Subhojit,
I was unable to find any specific name for the ip routing protocol purge interface feature so I was unable to look it up under Cisco Feature Navigator. Not even Configuration Guides seem to cover this feature. The only more exact reference about this command is located in Command References that appear to suggest that this command is integrated in various 'S' trains of IOS. However, those trains are service provider trains and none of them is available for 3845. While there were certain release notes documents even for 15.xM (mainline) releases that mentioned this command, there is no enough information to know whether this command is or will be ever supported on the 3845.
My best recommendation would therefore be to test the latest 15.1(3)T3 Advanced IP Services IOS for 3845 but if there is no such command available in that IOS, then for this platform, there simply appears to be no IOS supporting this feature.
Best regards,
Peter
