Webcast-Catalyst9k
IP Routing
network-A (192.168.1.0)-- > workstation-A --> swich-A --> router-A --> internet-A
network-B (192.168.2.0) --> workstation-B --> swich-B --> router-B --> internet-B
Can someone please advise me as to how I can make workstion-A internet traffic (http) to go through router-B instead of router-A.
Both routers are running EIGRP.
network-A: 192.168.1.0 subnet
network-B: 192.168.2.0 subnet
Workstation-A can ping all nodes on network-B and vice versa.
Thanks!
TIA
hieu
1 ACCEPTED SOLUTION
Bronze
Re: IP Routing
Yes,
And if you have problems with Policy based routing support on your switch, then I think you can try applying the configuration on rtrA and if its somehow connected to rtsb, set rtrb lan adr. as next-hop.
BR,
Bjornarsb
Bronze
Re: IP Routing
I assume that swa is connected to swb,
and that at least swa supports policy based routing.
Then it would be like this:
access-list 101 permit tcp 192.168.1.0 any eq www
interface fastethernet 3/1
ip policy route-map AtoB
route-map AtoB permit 10
match ip address 101
set ip next-hop 3.3.3.3 (swb or rtrb)
route-map AtoB permit 20
ps: The return traffic will return on rtrA,
unless you use Nat overload on rtrB :)
HTH,
Check the scroll-bar at the bottom right :)
BR,
Bjornarsb
Re: IP Routing
Hi Bjoornarsb,
Thanks for your response. I assume that those commands above to be implement in the switch-a. is this correct?
I'll try it out when I am back in the office later this afternoon.
Thanks!
hieu
Bronze
Re: IP Routing
Yes,
BR,
Bjornarsb
Re: IP Routing
I actually apply PBR in our core router and it worked out great.
Thanks for pointing me toward the right direction!
hieu
102
