IP SLA 877
jack samuel
Hello folks,
track 123 ip sla 1 reacheability
ip sla 1
  icmp-echo 10.10.10.10 source-interface Vlan1
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
ip route 0.0.0.0 0.0.0.0 20.20.20.20 track 123.
ip route 0.0.0.0 0.0.0.0 30.30.30.30 100
sh ip route track-table always shows me down. why ????/ Is there i m missing in the above configuration.i m doing with IOS 12.4 on router 877
13 Replies 13
cadet alain
Can you provide a topology diagram and put the output of:
-sh ip route 10.10.10.10
- sh ip cef exact-route "vlan1 IP"   10.10.10.10
-sh track 123
- sh ip sla statistics 1
Regards.
Alain
I am trying to track a default route pointing to ISP on my easy vpn client router, the router doen"t have a static route to 10.10.10.10 and there are no ip cef route to the specific destination.
The below status is when the track command is included in the static route.whenever i include a track command in the default route  my vpn connection disconnects and when i remove the track command the vpn connection comes up.
ip route 0.0.0.0 0.0.0.0 dialer0 track 123
TEST#sh track
Track 123
  IP SLA 1 reachability
  Reachability is Down
    6 changes, last change 00:00:24
  Latest operation return code: Timeout
  Tracked by:
    STATIC-IP-ROUTING 0
TEST#sh ip sla statistics
IPSLAs Latest Operation Statistics
IPSLA operation id: 1
Type of operation: icmp-echo
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *09:12:47.851 UTC Mon May 7 2012
Number of successes: 210
Number of failures: 154
Operation time to live: Forever
hi,
Can you manualy ping 10.10.10.10 sourced from vlan 1?
try
timeoute 2000
threshold 1000
plz Rate if it helped.
Soroush
Hope it Helps!
Soroush.
when i put ip route 0.0.0.0 0.0.0.0 dialer0 everything works fine. but when i put ip route 0.0.0.0 0.0.0.0 dialer0 track 123 everythng goes down.
I tried still the ip SLA commands which you sggested but still the situation is same.
IOS :
flash:c870-advipservicesk9-mz.124-24.T1.bin"
"10.10.10.10 source-interface Vlan1"
Is the network segment on vlan1 is being natted or no-natted if it goes via for VPN connection correctedly?
It seems to be that what it is failing.
thanks
Could you manually ping ur destination, sourced from VLAN 1?
because here i dont see any problems with ur SLA, track n rtr are just doing the same thing in different versions.
most probabely the problem is with reachability itself, try to remove or change the source-interface extension
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
rizwanr74
Level 7
Level 7
Hi Jack,
Please change highlighted value below.
change to.
track 123 rtr sla 1 reacheability
let me know, if this helps.
thanks
Rizwan Rafeek
Rizwan,
there is no option of rtr, i have always configured by rtr and it works fine,
TEST(config)#track 123 ?
  interface    Select an interface to track
  ip           IP protocol
  list         Group objects in a list
  stub-object  Stub tracking object
Dear Soroush
Yes i can ping the tracking IP when it is configured in the router as ip route 0.0.0.0 0.0.0.0 dialer0 and there is a default route in the table
BUT when i add a track keyword with a default route   ip route 0.0.0.0 0.0.0.0 dialer0 track 123 the default route from the routing table is been removed immediately and this is the reason i m losing the connectivity.
Dear Rizwan,
Yes it is an Easy vpn client connection and it is network extension mode , the local internal IP reaches the server it is not Natted.
Hi Jack,
I believe, it is the ip (10.10.10.10) you are expecting a echo-reply from, must be disabled for ping reply.
Try, a different, interface ip at HO router's IP instead, a pingable IP.
thanks
Rizwan Rafeek.
Rizwan,
"No" this IP is pingable with a source address of interface vlan 1 when i configure a default route such as
ip route 0.0.0.0.0 0.0.0.0 dialer0
BUT
It it not pingable when a default route is configured such as ip route 0.0.0.0 0.0.0.0 dialer 0 track 123 becz what actual it is happening is that after applying the track command in the ip route when i do sh ip route there is no default route in the routing table.
Is it i have to upgrade the IOS for the router,it is strange becz after entering the track 123 command in ip route the default route disappears from the routing table.
can you post sanitized config and output of debug track and debug ip icmp.
Regards.
Alain
Here are the attahced.
