03-04-2012 11:39 PM - edited 03-04-2019 03:32 PM
Hi!
I have 2 ip sla tests ( icmp-echo operation). I need to write tcl script that will work if tests finish there operations with timeout.
I wrote script for 1 operation and it works:
::cisco::eem::event_register_ipsla operation_id 1
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set evtData [event_reqinfo]
set evt_cond $evtData(condition)
set bb "Cleared"
if { $evt_cond == "Cleared" } {
action_syslog msg $bb
exit 0
if [catch {cli_open} result] {
puts stderr "CLI OPEN failed ($result)"
exit 0
array set cfd $result
action_syslog msg "Ocurred"
cli_exec $cfd(fd) "enable"
cli_exec $cfd(fd) "configure terminal"
cli_exec $cfd(fd) "router bgp 1"
cli_exec $cfd(fd) "neighbor 3.3.3.2 shutdown"
cli_exec $cfd(fd) "end"
catch {cli_close $cfd(fd) $cfd(tty_id)}
exit 0
Help me please. How i can process 2 tests in one script?
Solved! Go to Solution.
03-05-2012 12:30 AM
Hi Maxim ,
I would try to use correlate :
event manager applet name
event tag track-1 track 1 state down
event tag track-2 track 2 state down
trigger
correlate event track-1 and event track-2
action ....
Dan
03-05-2012 12:30 AM
Hi Maxim ,
trigger
action ....
Dan
03-05-2012 01:31 AM
Thanks. Do u know, why if i type code to tcl script:
::cisco::eem::event_register_ipsla tag test1 operation_id 1
::cisco::eem::event_register_ipsla tag test2 operation_id 2
::cisco::eem::trigger
::cisco::eem::correlate event test1 and event test2
and try to accept policy i have next:
R1(config)#event manager policy test3.tcl
UpdateStringProc should not be invoked for type
UpdateStringProc should not be invoked for type fg
And it doesn't work
