IP SLA Jitter Monitoring
Hi All,
This concerns a problem with IP SLA jitter monitoring not set up through the CLI.
when setting up an IP SLA jitter probe with the CLI, monitoring works correctly & jitter statistics are displayed.
#show ip sla monitor configuration 1234
IP SLA Monitor, Infrastructure Engine-II.
Entry number: 1234
Owner:
Type of operation to perform: jitter
Target address: x.x.x.x
Source address: x.x.x.x
Target port: 7
Source port: 1
Request size (ARR data portion): 32
Operation timeout (milliseconds): 5000
Number of packets: 100
Interval (milliseconds): 50
Type Of Service parameters: 0x0
Control Packets: enabled
Operation frequency (seconds): 30
When setting this up through SNMP, the monitoring works for a few seconds and then stops. Jitter statistics are cleared (reset to zero's).
#show ip sla monitor configuration 8647
Entry number: 8647
Owner: InfoVista Server
Target port: 7
Source port: 0
Request size (ARR data portion): 460
Operation timeout (milliseconds): 2000
Interval (milliseconds): 100
Control Packets: disabled
Operation frequency (seconds): 60
I noticed that in the second configuration the Control Packets are disabled.
Only thing that Cisco release notes mentions about this: "Do not use the control keyword with this command (type jitter). The control disable keyword combination will disable IP SLAs control packets and cause the operation to malfunction. The default is control enable."
So, it seems that this Control Packets option should always be enabled.
Remote SLA responders are configured identically.
Can anyone give me more technical info about these Control Packets and how to correctly setup the probe configuration (not through CLI)?
Multiple probes are configured on the systems; they need to be configured through SNMP.
Running on Cisco systems 3845 with IOS 12.4(25b).
1779
