11-27-2013 01:04 PM - edited 03-04-2019 09:42 PM
Pretty sure the answer is "yes", but is there a special license required to configure IP SLA monitors in IOS 15.1? I'm trying to do this on a 2921 running
15.1(4)M7, ipbase feature set.
Router(config)#ip sla ?
key-chain Use MD5 Authentication for IP SLAs Control Messages
responder Enable IP SLAs Responder
server IPPM server configuration
Solved! Go to Solution.
11-27-2013 01:17 PM
You have a licensing issue - to use IP SLA monitoring you need at least the IP Data or Security license on your 2911. IP Base does not support IP SLA monitoring.
11-27-2013 01:17 PM
11-27-2013 01:21 PM
Looks that way. UCK9 version must also work too, on a different 2921 with that license I see this:
(config)#ip sla ?
<1-2147483647> Entry Number
auto IP SLAs Auto Configuration
enable Enable Event Notifications
11-27-2013 10:18 PM
Hi John,
There are frew commands u can use it but not all.
Pleae check this link to clarify:
11-27-2013 11:34 PM
Yeah. Kind of a bummer. I consider SLA monitoring a pretty mainstream feature and don't see why you'd need a license upgrade for it.
What really puzzles me is they seem to be fully supported with a UC, directly contradicting the documentation. Could be a bug.
#show ver
uc uck9 Permanent uck9
data None None None
#conf t
(config)#ip sla ?
enable Enable Event Notifications #ip sla ?
