Webcast-Catalyst9k
Bronze
IP SLA Monitor on ISRG2
Pretty sure the answer is "yes", but is there a special license required to configure IP SLA monitors in IOS 15.1?  I'm trying to do this on a 2921 running
15.1(4)M7, ipbase feature set.
Router(config)#ip sla ?
  key-chain  Use MD5 Authentication for IP SLAs Control Messages
  responder  Enable IP SLAs Responder
  server     IPPM server configuration
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Purple
Re: IP SLA Monitor on ISRG2
You have a licensing issue - to use IP SLA monitoring you need at least the IP Data or Security license on your 2911. IP Base does not support IP SLA monitoring.
VIP Purple
Bronze
Looks that way.  UCK9 version must also work too, on a different 2921 with that license I see this:
(config)#ip sla ?
  <1-2147483647>          Entry Number
  auto                    IP SLAs Auto Configuration
  enable                  Enable Event Notifications
VIP Purple
Hi John,
There are frew commands u can use it but not all.
Pleae check this link to clarify:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10537_Products_White_Paper.html#wp9000807
Bronze
Yeah.  Kind of a bummer.  I consider SLA monitoring a pretty mainstream feature and don't see why you'd need a license upgrade for it.
What really puzzles me is they seem to be fully supported with a UC, directly contradicting the documentation.  Could be a bug.
#show ver
uc            uck9          Permanent      uck9
data          None          None           None
#conf t
(config)#ip sla ?
  enable                  Enable Event Notifications #ip sla ?
204
