IP SLA on CAT6500
n.poongsawad
Dear Experts,
I need to use IP SLA to monitor remote routes on CAT6500
CAT6500 is running "sup-bootflash:s72033-jk9o3sv-mz.122-18.SXD7b.bin" on SUP720
Feature Navigator said it is
ENT FW W/MPLS/IPV6/SSH/3DES
After drill down into feature set I found that this version support for IP SLA such IP SLAs - ICMP Path Echo Operation
BUT, back to console I can not do such (config) ip sla command (not found cmd CAT6500(config)# ip sla 1)
What I did wrong or others cmd imply this ip sla process?!
Thank mate in advance. Any suggestion is welcome.
Nipat.p
n.poongsawad
I discovered it my self, many difference way to config IP SLA.
I did CCIE lab just on specific IOS version that using (config) ip sla 1 blablabla
Now, on mentioned version according to document
Reliable Static Routing Backup Using Object Tracking
We should use (config) rtr 1 ......
