IP SLA problems
rasoftware
have this config
ip sla 1
icmp-echo 62.6.200.5
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
track 100 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 "our-next-hop" track 100
ip route 0.0.0.0 0.0.0.0 Dialer0 254
ip nat inside source route-map ispA interface FastEthernet0 overload
ip nat inside source route-map ispB interface Dialer0 overload
access-list 40 remark IPs for NAT policy
access-list 40 permit 192.0.0.0 0.255.255.255
access-list 101 permit icmp any host 62.6.200.5 echo
route-map LOCAL_POLICY permit 10
match ip address 101
set interface FastEthernet0
route-map ispB permit 10
match ip address 40
match interface Dialer0
route-map ispA permit 10
match ip address 40
match interface FastEthernet0
The track doesn seem to work, when I have default route to metric 1 and no track it works.
I have this config working where I have two DSL ports but this has 1 DSL and 1 FE.
Will this work?
2 Accepted Solutions
Can you change your route-map to look like below:
set ip next-hop 195.x.x.x
Make 195.x.x.x the same as what you have in your static route and re-try your tests
Hope that helps - pls rate the post if it does.
Paresh
Alright... can you change your icmp-echo statement so that it reads like the following:
icmp-echo 217.32.63.202 source-interface FastEthernet0
Then, repeat your tests :-)
Paresh
30 Replies 30
pkhatri
Level 11
Level 11
I presume you can do a ping to 62.6.200.5 without any problems.
Have you got the following configured:
ip local policy route-map LOCAL_POLICY
Paresh
Yes ip local policy route-map LOCAL_POLICY .
If I change the route to a normal static I can ping that address.
I have attached a more complete config
Have you started the IP sla using
If yes, can you show the output of
sh ip sla statistics and sh track
Looks like it not working, I have also tried another IP as the ping address:
Track 100
Response Time Reporter 1 reachability
Reachability is Down
3 changes, last change 01:38:32
Latest operation return code: Timeout
Tracked by:
STATIC-IP-ROUTING 0
Track 100
Tracked by:
STATIC-IP-ROUTING 0
rasoft-gw#sh ip sla stat
Round Trip Time (RTT) for Index 1
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *14:28:29.339 PCTime Thu Feb 23 2006
Number of successes: 0
Number of failures: 54
Operation time to live: Forever
Paresh
Thanks Paresh - helped me out yet again! Much appreciated
Still having a little trouble with this. The FastEthernet primary WAN keeps declaring the route down.
Track 100
1 change, last change 1w0d
Tracked by:
STATIC-IP-ROUTING 0
and
Latest operation start time: *09:35:09.847 PCTime Wed Mar 8 2006
Number of failures: 48
When it first boots it works for a while, I dont know why it switchs to the fail over link. It also never switches back.
I have tried using a different destination ICMP address but its the same.
I post complete config for clarity.
Could you try the following and post the output:
debug ip policy
ping 217.32.63.202
Paresh
It does now fail over, when i disabled FE as test it switched to backup ADSL. However, it has not switched back.
I run you command (both links available - using dialer:
rasoft-gw#debug ip policy
Policy routing debugging is on
rasoft-gw#ping 217.32.63.202
Sending 5, 100-byte ICMP Echos to 217.32.63.202, timeout is 2 seconds:
Success rate is 0 percent (0/5)
When I re-run (after a reload I get)
rasoft-gw#sh track
Track 100
Reachability is Up
2 changes, last change 00:00:24
Latest operation return code: Over threshold
Latest RTT (millisecs) 16
Tracked by:
STATIC-IP-ROUTING 0
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/19/20 ms
Doing sh ip route indicates dialer is still primary despite FE being up:
S* 0.0.0.0/0 is directly connected, Dialer0
i also notice that non of the policy based routes are being used:
rasoft-gw#sh route
route-map LOCAL_POLICY, permit, sequence 10
Match clauses:
ip address (access-lists): 101
Set clauses:
ip next-hop 195.172.169.x
Policy routing matches: 1913 packets, 122612 bytes
route-map ispB, permit, sequence 10
Match clauses:
ip address (access-lists): 40
interface Dialer0
Set clauses:
Policy routing matches: 0 packets, 0 bytes
route-map ispA, permit, sequence 10
Match clauses:
Set clauses:
Ok I think i have spotted my own problem:
Timeout set to 2 (chaned 1500)
no frequency set
I have changed these will post back if still unreliable
One other thing, mate...
Change your route-map so that it looks like this:
set ip next-hop 195.172.169.99
set interface null0
Paresh
thanks Paresh, I have made the change and will monitor.
Whats the significance of the null0?
Also, I found this which was helped me for anyone looking a PBR.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00801d862d.html#wp1071380
The 'interface null0' statement means that the ping packet will only be sent out the specified IP next-hop. If that next-hop is down, it will be dropped. The point of this is to ensure that the ping only succeeds when sent out through the interface being monitored. There could be other ways of getting out but we are only interested in monitoring this interface.
Paresh
