Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ip sla reaction-configuration question
My goal is to have "track 111" go from up to down in the event of three successive ping losses. I wish the configuration guide had some more simple examples. Anyhow - when I run "show ip sla reaction-trig 1" IOS responds "Reaction trigger not configured" I don't understand why not. And I'm not clear if my end-goal of track going down on 3 losses is met. Any ip sla masters on here??
track 111 rtr 1
ip sla 1
icmp-echo 192.168.95.2
frequency 30
ip sla reaction-configuration 1 react rtt threshold-type consecutive 3 action-type trapAndTrigger
ip sla schedule 1 life forever start-time now
Cisco2811ILG#sho ip sla reaction-configuration
Entry number: 1
Index: 1
Reaction: rtt
Threshold Type: Consecutive
Rising (milliseconds): 5000
Falling (milliseconds): 3000
Threshold CountX: 3
Threshold CountY: 5
Action Type: Trap and trigger
Cisco2811ILG#sho ip sla reaction-trigger
Entry number: 1
Cisco2811ILG#sho ip sla statistics
Round Trip Time (RTT) for Index 1
Latest RTT: 16 milliseconds
Latest operation start time: *13:26:31.017 EST Thu Mar 5 2009
Latest operation return code: OK
Number of successes: 28
Number of failures: 0
Operation time to live: Forever
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsthresh.html#wp1082269
Re: ip sla reaction-configuration question
Change your react from rtt to timeout
I have simplfied the config a bit from yours so don't copy it (my timers are very low), but mine works
ip sla monitor 1
type echo protocol ipIcmpEcho 192.168.1.2
timeout 1
frequency 3
ip sla monitor reaction-configuration 1 react timeout
ip sla monitor schedule 1 life forever start-time now
Router#sh ip sla monitor statistics
Round trip time (RTT) Index 1
Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *19:46:33.155 UTC Thu Mar 5 2009
Latest operation return code: Timeout
Number of successes: 1
Number of failures: 20
Router#sh ip sla monitor reaction-configuration
Entry number: 1
Reaction: timeout
Threshold Type: Never
Threshold Count: 5
Threshold Count2: 5
Action Type: None
Thank-you. So in your example it appears that an ICMP timeout is defined as 1 second with no reply and then monitor operation runs with a frequency of every 3 seconds. And your reaction config is saying if there are 5 timeouts then then fail. Correct?
It's 1 ms with no reply.
I think your issue is down to the fact that you where using round trip times rather than timeout (react rtt).
I am allowing 5 timeouts before alerting ( the default), you can amend this with threshold-type .
1849
