Community Member
ip sla & vpn with more than 2 Routers
Hi Everyone,
The problem is bellow :
First, I have 2 cisco routers with 2 links, the first link is primary and the second is a backup. I configured this classicaly by using ip sla (with icmp echo to verify the continuity of the link), than, I created 2 vpn each one on one link, that means that traffic always uses vpn between the two routers for the primary link and aloso for the backup link.
Now, I want to add another router and I want the same behavior between it and the first router.
Is it possible to connect the same interfaces on the first router (logically) to more than 2 routers and uses ip sla with evry link ?
Is it possible to use vpn in evry link here ? how ?
Config with only 2 routers is :
hostname Routeur_Siege
track 10 ip sla 1 reachability
delay down 1 up 1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 5
encr aes
group 2
crypto isakmp key vpnsttat address 3.3.3.3
crypto isakmp key Sttat*2012 address 4.4.4.4
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set STTAT-VPN esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
set peer 3.3.3.3
set transform-set ESP-3DES-SHA
match address VPN-ACL
crypto map VPN-SEC 40 ipsec-isakmp
set peer 4.4.4.4
set transform-set STTAT-VPN
interface GigabitEthernet0/0
description SDSL
ip address 1.1.1.1 255.255.255.248
ip nat outside
ip virtual-reassembly in
ip tcp adjust-mss 1300
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
no ip proxy-arp
ip nat inside
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 0/35
  pppoe-client dial-pool-number 1
interface Dialer1
description Connection_Secondaire
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname ************
ppp chap password 0 *************
ppp pap sent-username *********** password 0 *********
crypto map VPN-SEC
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map MAP interface Dialer1 overload
ip nat inside source route-map MAP-2 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 Gi0/0 track 10
ip route 0.0.0.0 0.0.0.0 Dialer1 20
ip access-list extended LAN-ADSL
ip access-list extended VPN-ACL
ip sla 1
icmp-echo 3.3.3.3 source-interface GigabitEthernet0/0
threshold 2000
timeout 2000
frequency 5
ip sla schedule 1 life forever start-time now
route-map MAP permit 10
match ip address LAN-ADSL
match interface Dialer1
route-map MAP-2 permit 10
match interface GigabitEthernet0/0
Everyone's tags (9)
407
