IP SLA
I have a 1841 with C1841-ADVSECURITYK9-M), Version 12.4(3b) IOS. I have second 1801 with C180X Software (C180X-BROADBAND-M), Version 12.4(2)XA.
When I run router#ip sla ? on 1841 I get "monitor" option. When I run it on 1801 I set a whole different set of options? Are the features missing from 1801 release?
1 ACCEPTED SOLUTION
Purple
Re: IP SLA
Alright, I've found out what the deal is here.. the command syntax for IP SLA has changed starting 12.4(4)T. That means that sub-commands that appeared under the 'ip sla monitor' hierarchy level now appear directly under the 'ip sla' command hierarchy level.
For example, the command 'ip sla monitor low-memory' command is replaced by the 'ip sla low-memory' command
Therefore, there is no feature that is missing (except for the differences I highlighted earlier).. it's just a change in syntax.
Hope that helps - pls rate the post if it does.
Paresh
Purple
Re: IP SLA
There is indeed a difference in the IP SLA features supported by the two images.
The 1841 image supports:
IP SLAs DNS Operation
IP SLAs FTP Operation
IP SLAs HTTP Operation
IP SLAs ICMP Echo Operation
IP SLAs ICMP Path Echo Operation
IP SLAs MPLS VPN Aware
IP SLAs Multi-Operation Scheduler
IP SLAs One-way Measurements
IP SLAs Path Jitter Operation
IP SLAs Reaction Threshold
IP SLAs Scheduling
IP SLAs Sub-millisecond Accuracy Improvements
IP SLAs TCP Connect Operation
IP SLAs UDP Echo Operation
IP SLAs UDP Jitter Operation
IP SLAs UDP VoIP Operation
IP SLAs VoIP Threshold Traps
The 1801 image supports:
IP SLAs Scheduling
So the 1801 supports fewer operations than the 1841 image..
To get the full set of IP SLA features on the 1801, upgrade to the 'Advanced IP Services' feature set for the same version.
Paresh
Re: IP SLA
I was using IP SLA monitor for reliable static routes on 1841 with advanced IP IOS. I guess i cant achieve the same with the 1801 and its more limited features?
Purple
Re: IP SLA
YOu should still be able to use that. What do you get when you do a 'ip sla ?' in config mode on the 1841 ? Would you be able to post that ?
Paresh
Re: IP SLA
On 1841 i get
router(config)#ip sla ?
monitor IP Service Level Agreement Monitor
on 1801 i get
config)#ip sla ?
<1-2147483647> Entry Number
apm IP SLAs Application Performance Monitoring
Configuration
group Group Configuration or Group Scheduling
key-chain Use MD5 authentication for IP SLAs Control Messages
logging Enable Syslog
low-memory Configure Low Water Memory Mark
reaction-configuration IP SLAs Reaction-Configuration
reaction-trigger IP SLAs Trigger Assignment
reset IP SLAs Reset
responder Enable IP SLAs Responder
restart Restart An Active Entry
schedule IP SLAs Entry Scheduling
slm Service Level Management
Purple
Re: IP SLA
Paresh
543
