IP to X.25
michaelbroche
I have an application where I would like to map IP addresses on Ethernet to a router connecting via x.25 to many remote sites. Is there an IOS feature where I can create a routing/lookup table that equates an IP address with an X.25 address for up to 2,000 X.25 nodes?
7 Replies 7
paolo bevilacqua
Yes, that is a normal use for X.25 in IOS.
Thank you p.bevilacqua.
Is there a particular IOS command/feature you would recommend and does it require the Enterprise version of IOS?
Mike
For a very large number of map entries, use the following:
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t5/feature/guide/x25dns.html
Thank you again.
The only difference with my app is that I would use an ip address on a single host mapped x.25 devices over an x.25 cloud. More like TCP over X.25.
Can it still work?
DNS is good idea... : )
Sorry, I do not quite understand what is you case.
Sngle IP host conencted to router via Ethernet. The host sends to a variety of IP addresses on the same subnet which are forwarded to a single router (default gateway). Each IP address in the subnet maps to an x.25 remote address accessed through an x.25 cloud.
That is normal working and you can use the DNS feature, or configure the mapping in the router, as you prefer.
